Help!!
Old Mar 16, 2008 | 10:00 PM
Nikteazer's Avatar
Nikteazer
Default Help!!
After a cossie and have been offered this in part ex for my car, it's apparantly been converted to 4wd, how can I tell if it's a proper conversion or not? Apparently the chassis numbers match the 2wd log book but I just have a little gut feeling that all's not quite right???
Desperate to have another cossie, and love the engine spec! Help!
Anyone know the car?
http://cgi.ebay.co.uk/sierra-coswort...QQcmdZViewItem
Old Mar 16, 2008 | 10:32 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I don't know the car, but looking at the ad I can't see where it says its converted?
to convert 2wd to 4x4 it needs a bulge cut in the floor on drivers footwell to clear transfer box and also "might" need half cuts out of the chassis rails for the driveshafts and also all the 4x4 stuff swapped over.
Old Mar 16, 2008 | 10:33 PM
Physio's Avatar
Physio
Hello Nik
Old Mar 16, 2008 | 10:39 PM
Nikteazer's Avatar
Nikteazer
Hello darlin!
Dan. it doesn't say it's converted. the guy said it has been, so if I was to as for pics then i guess i'd want some of the drivers footwell?
Old Mar 16, 2008 | 10:44 PM
wirralphil's Avatar
wirralphil
Originally Posted by Nikteazer
Hello darlin!
Is the car far from you?
no disrespect but are you Mechanically mindied to know if anything is untoward? ask him for some proof, anyone to be shy is usually a little naughty,
Old Mar 16, 2008 | 10:48 PM
Dan@Rapid-Ford
If its had 4x4 carpet in you won't see it as the carpet is formed and will be that shape until it gets flattened.
TBH you will have to go look at it and get underneath to see the work done.
I.e has it got 2wd rear diff or 4x4? what gearbox crossmember has it got (hope it not a angle iron conv)
Its not a difficult conv once the mods have been done, it's just replacing what has been taken off.
One thing on the advert is he lists it's got 4pots is a bit as the brakes are different 2wd to 4x4 and unless brackets are made the don't swap over.
Nikteazer's Avatar
Nikteazer
Well he said the numbers by the drivers seat matches the 2wd log book, but then he said that it has a 2wd engine in it, am I not right in saying that this is a 4wd engine...
Old Mar 16, 2008 | 10:51 PM
Dan@Rapid-Ford
that pic looks dodgy, its a bit small but looks like a 4x4 manifold, 4x4 head and 4x4 rail and reg, 4x4 header tank and thermostat
Thrush's Avatar
Thrush
Irritating c........
Hello Nik - long time no speak
Old Mar 16, 2008 | 10:53 PM
Dan@Rapid-Ford
and abs tank IIRC
a lot of unnessary effort to swap from 2wd to 4x4 could be trouble
Old Mar 16, 2008 | 10:54 PM
Nikteazer's Avatar
Nikteazer
Hello thrush, how's things!
Dan, exactly why i've got a gut instinct that something's not as it should be.
Old Mar 16, 2008 | 10:59 PM
Dan@Rapid-Ford
did he say he converted it? as he said he px'd it
Old Mar 16, 2008 | 11:01 PM
Nikteazer's Avatar
Nikteazer
No, he said the previous owner had done it.
Old Mar 16, 2008 | 11:02 PM
RichardPON's Avatar
RichardPON
Easy woman!
Old Mar 16, 2008 | 11:06 PM
Nikteazer's Avatar
Nikteazer
Easy woman!
Hello you! wanna buy a scooby?!
Old Mar 17, 2008 | 01:12 AM
g10ens's Avatar
g10ens
Why would someone go to all that effort of converting it to 4x4? Why didnt they just buy a 4x4 in the first place? The only reason i can see that somebody would bother removing the engine, cutting their floor about and messing with the chassis rails (if that mod needs to be done) is if you were for some reason (perhaps a front end smash) replacing the whole front end anyway and just happened to have a load of 4x4 running gear including brakes lying about. Perhaps it is just a genuine conversion that somebody did as a project but as i said why bother? At the end of the day all thevye created is something which has already been mass produced by ford and they could have just gone straight out and bought. To me it would be like cutting the roof of an xr3i to make it into a cabriolet!
Old Mar 17, 2008 | 08:57 AM
Nicole's Avatar
Nicole
Follow your gut feeling Nik, it's there for a reason hun. I personally wouldn't take the risk, i know you really want another cossie but try and wait for the right one, will be worth it in the end.....these damn cars are money pits at the BEST of times LOL
Old Mar 17, 2008 | 08:59 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
The lovely Nik
RichardPON's Avatar
RichardPON
Probably not
Old Mar 17, 2008 | 09:14 AM
Trist's Avatar
Trist
Looks like trouble Nik. better ones will come up just keep an eye out.
Old Mar 17, 2008 | 09:40 AM
Twellsie's Avatar
Twellsie
power seems a little optomistic too on a T3
Old Mar 17, 2008 | 10:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Beware... a lot of things appear to be late on that car that arent mentioned. Fuel filler Flap and doorcards included as far as i can see.
Originally Posted by Twellsie
power is total bollox
Agreed.
Old Mar 17, 2008 | 11:27 AM
Twellsie's Avatar
Twellsie
Originally Posted by Stu @ M Developments
Agreed.
nice edit lol
Old Mar 17, 2008 | 12:06 PM
Nikteazer's Avatar
Nikteazer
Ha ha! Thanks for the help guys! I knew i'd get the answer I needed here! And nicole, ure so right.... I have always followed my gut instinct I guess i'm just so desperate for another cossie that I tried to ignore it!!
Thanks again for your help.
Old Mar 17, 2008 | 09:25 PM
DazC's Avatar
DazC
Stranger!!
And I think that car is dodgy.
