HELP please; troubles with my brakes...
Old Oct 19, 2004 | 11:06 PM
cossiemen's Avatar
cossiemen
Whassup
Default HELP please; troubles with my brakes...
...was trying to fix my brakes today, front ones no problem, rear ones are shit.
followed the step by step instructions in the cosworth manual but nothing realy happend on the rear ones.
when I press on the breakpedal i have pressure but when opening the rear brake bleed valves there's NO oil coming through
abs pump is running, i can hear it 'buzzing' as described in the cossie manual.
calipers are in very good condition and i fitted some brandnew hoses, oil is also brandnew
what can be the problem ?
thx in advance
Old Oct 19, 2004 | 11:19 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
have you bled them properly?
starting furthest from the servo working your way to the closest? lower the back end of the car if u can when doing the rears! does the handbrake work fine? can elimenate pads/calipers if so i think
Old Oct 19, 2004 | 11:27 PM
cossiemen's Avatar
cossiemen
Whassup
ermmm... not realy
started with the front ones; right one first, secondly left one and worked my up too the rear ones, as discriped in the cosworth manual or i'm i that stupid to misunderstand the manual?
the handbrake works perfectly
Old Oct 19, 2004 | 11:34 PM
vroooom ptssssh
It Wasnt Me!
lol this is taken from a website!
"This is the process of removing air bubbles from the brake system by pumping fluid through the lines. Air bubbles are bad because they compress when pressure is applied resulting in a low or spongy feeling pedal. The correct procedure for bleeding the brakes on most RWD vehicles is to start at the furthest wheel. Do the right rear then left rear brake, followed by the right front and left front brakes. "
was u in a rush
Old Oct 19, 2004 | 11:46 PM
cossiemen's Avatar
cossiemen
Whassup
nope... i wasn't in a rush mate
damn me
now what? start all over again?
Old Oct 20, 2004 | 12:08 AM
CraigN's Avatar
CraigN
you need to do passenger side rear first
then drivers side rear
then passenger front
then drivers side front
abs pump should shoot fluid out on the back
Old Oct 20, 2004 | 12:20 AM
cossiemen's Avatar
cossiemen
Whassup
vroooom ptssssh, right, thanks mate
CraigN, thanks mate, shall i just re-do it ? or any other suggestions?
Old Oct 20, 2004 | 02:32 AM
vroooom ptssssh
It Wasnt Me!
Np buddy, glad to help. Mind your cossie will maybe be left hand drive so watch out what wheels furthest away?
Old Oct 20, 2004 | 02:38 AM
cossiemen's Avatar
cossiemen
Whassup
yep, my cossie is a left hand drive one but it's the same way like your cars.
my abs pump sits on the left side of my car so i have to do the passenger side rear first, then drivers site rear, etc. etc...
Old Oct 20, 2004 | 02:43 AM
vroooom ptssssh
It Wasnt Me!
aye, good man, let's know how it goes, mind if u can lower the rear of the car, then do that or even raise the front, helps
Old Oct 20, 2004 | 06:56 AM
whitneyd's Avatar
whitneyd
Just did mine last night. The rear pistons are a c*nt to get turned back in unless you got the right tool. Which of course I don't. Good luck with the bleeding.
Old Oct 20, 2004 | 11:03 AM
cossiemen's Avatar
cossiemen
Whassup
turning in the rear pistons is death easy (even without the right tools)
you have to create your own tools which i did
will have a second go this afternoon
Old Oct 20, 2004 | 11:56 AM
Ian Godney's Avatar
Ian Godney
On the rear calipers , you need to bleed them different from the front , pump the pedal a few times to bring the ABS pump on , when it stops get someone to press the brake and hold it down , now open the bleed nipple on the caliper and it will pump out itself , you dont need to pump the pedal , just keep it down , it will bleed straight away.
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
