Evo 6 500BHP ATW 2000cc!!
Here's one we've just finished......
http://www.youtube.com/watch?v=dI9OjqZ0FCU
That's going to be rude.
Mike - It's not Ross'. I can't really say whose it is until I have at least linked the videos to him!!
Ricky, I couldn't see the comment even though I got a mail saying there was one? The breather system was built by us and the rocker cover has been drilled and fitted with -10 Aeroquip.
Euan, not had a chance to take the graphs off yet, but I will do and post them to show you. You should see the boost curve!!
I want to see the boost curve also. What does it peak at?
Must boost pretty late, surely?
Cheers christian
what does that 500 ATW make ATF?
BTW, Gary's has two -10 Breathers, so does Ross' (the other 700bhp Evo we had alot to do with), however, we didn't build the engine in the one above, but did put an awful lot of work/love etc into making it all what it is today.
I have a GT35, on a 2.3 stroker. I'm currently getting high crank case pressures, so the stock breather system is something i'm going to be sorting in this coming week. I don't think 2 5mm breathers cut's it running a Gt35 on 2 bar+.
504 on race fuel is awesome!
What gearbox and rear diff is been used?
I'm with you I think. Its the bit of the graph i wanted to look at.
It must come on boost pretty early tho, not sure if it will be as early on the road. but full boost by 4750 is respectable on a 2litre with a gt35 IMO. But if you look at the graph it looks like its JUST hit full boost on a pretty steep boost curve. Things will probably start at about 4250?
cant be done with that dyno mate,to get a flywheel figure the ramp rate is preset
doesnt cause us a problem but i could have started the run slightly earlier but them graphs are from the mapping and i never did one that started slightly earlier
