what next on engine build??????
next question people! once my new uprated engine is finished (still running standard turbo, intercooler) what is the next best thing to go for in terms of more power? (never satisfied)
liam
p.s this is what is already done:
LIST OF PARTS FITTED TO REBUILT ENGINE
REBORE
PISTONS
CRANK GRIND
SHELLS
OIL PUMP
WATER PUMP
PICK UP PIPE
BLOCK SKIM
HEAD SKIM
4 X EXHAUST VALVES
REFACE /REPLACE INLET VALVES
NEW VALVE GUIDES
CUT VALVE SEATS
NEW HEAD BOLTS
ALL GASKETS AND SEALS
CAM SHAFT
8 X HYD LIFTERS
CAM BELT
CAM BELT TENSIONER
WATER PUMP
PLUGS
OIL AND FILTER
ALL CEANED AND PAINTED
PLUS STAGE 2 CHIP WITH -31 ACTUATOR
RUNNING 200BHP APPROX
liam
REBORE
PISTONS
CRANK GRIND
SHELLS
OIL PUMP
WATER PUMP
PICK UP PIPE
BLOCK SKIM
HEAD SKIM
4 X EXHAUST VALVES
NEW VALVE GUIDES
CUT VALVE SEATS
NEW HEAD BOLTS
CAM SHAFT
8 X HYD LIFTERS
CAM BELT
CAM BELT TENSIONER
WATER PUMP
PLUGS
OIL AND FILTER
depends on what parts you have used, Ie, what mains, big ends, are the standard bearings, or Race bearings, or pinto bearings for that matter how much has the crank been ground, what bore is the block on, what gaskets seals, head gaskets, compression ratio, cams, turbo, we need a lot lot more info.
For all we know it could be a harvey 500/500 engine, or barry from round back has built it.
more info needed
more info needed
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Aug 27, 2015 08:56 PM
