Head Rattle.
Old Jan 18, 2008 | 11:52 AM
Damien.'s Avatar
Damien.
Default Head Rattle.
Bad news, after only owning my car for 5 days its already encountered problems. I started it this morning to come to work and it was running very rattly.
The rattle came from the top end of the engine, and when revved past 2.5k revs it would feel like a miss fire.
Any ideas ? Help.
Old Jan 18, 2008 | 12:37 PM
LHD220Turbo's Avatar
LHD220Turbo
how long is a bit of string?
What car is it?
Moondust_crust's Avatar
Moondust_crust
would help if you put what car, what engine etc
Old Jan 18, 2008 | 12:44 PM
Damien.'s Avatar
Damien.
Series 2 Rs Turbo, CVH 1.7 Engine.
Its a Stage 3 jamsport head, newman cams, solid lifters.
Old Jan 18, 2008 | 05:52 PM
Damien.'s Avatar
Damien.
Right, ive removed my rocker cover.
Cant see anything there that would be causing the problem. It got dark, so tomorrow im going to check the rockers, springs and tappets. I hope its a cheap solution.
Old Jan 20, 2008 | 10:29 AM
chill4x4saph's Avatar
chill4x4saph
could be one of a few things, (especially if jamsport have touched it!) possibly a sticking valve, does it look like its had a new cambelt recently?, as could be a sticking (bent) valve!
Old Jan 20, 2008 | 04:37 PM
Karl's Avatar
Karl
Norris Motorsport
Usually noisy engine and CVH means no/low oil pressure. Check this first before going any further!
Should be minimum 15psi with HOT oil at idle.
When hot, engine should have minimum 40psi pressure at 2500rpm.
(Note: hot means oil temps of 80DegC or more, which means engine should be run for a minimum of 15 minutes to warm up)
Old Jan 20, 2008 | 06:47 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
if it a newman cam its got solid liftters that need to be adjusted to take up the clearance set with a feeler gauge
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
