Traffic Lights
Old Jan 2, 2008 | 06:28 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default Traffic Lights
Why is that people think that flashing head lights at them will make them change! It Wont!
Old Jan 2, 2008 | 06:32 PM
cossie04's Avatar
cossie04
My mate does it and reckon it works, it don`t tho. Do they work the same as temporary lights?
Old Jan 2, 2008 | 06:34 PM
dazoriginal's Avatar
dazoriginal
prodigal son
good topic , i think flashing at temp lights does work
RS LOZWORTH
Im a traffic signal engineer and they either have loops in the road to detect vehicles or microwave detectors on top of the heads that detect vehicle moving towards them- these are used on temp lights
Old Jan 2, 2008 | 06:35 PM
rs_turbo_ant's Avatar
rs_turbo_ant
i do it and it works 4 me its the little box on top of the lights only works at night and if no one is on the other set of lights
Old Jan 2, 2008 | 06:38 PM
dazoriginal
prodigal son
you should ave waited for lots of replys then waded in with that
RS LOZWORTH
thats just chance that they change- i work on traffic lights everyday and know exactly how they work and flashing lights 100% DOSENT
C4llyT's Avatar
C4llyT
What's with one's on a major road, that at 4am go red, and just as you stop go green, when there's no traffic at the minor road?
Old Jan 2, 2008 | 06:39 PM
RS LOZWORTH
lol i just thought that
Old Jan 2, 2008 | 06:41 PM
RS LOZWORTH
when there is no traffic at night the lights auto go back to red as part of the config most of the time, in theory they should change back to green when you get there unless you are SPEEDING
Old Jan 2, 2008 | 06:44 PM
C4llyT's Avatar
C4llyT
They default to the minor road traffic??
The timing of it suggests there are sensors in the road then, as if sensed your lights would go to red when detects them, which would be crap
Old Jan 2, 2008 | 06:46 PM
RS LOZWORTH
they default to all red everywhere then when you come along at 4am they go green unless there is a fault, traffic lights work in so many diffrent ways
Old Jan 2, 2008 | 06:50 PM
StephenC's Avatar
StephenC
..BS Motorsport..
what does it mean when the little red light comes on the grey control boxes at the side of the road then?
Old Jan 2, 2008 | 06:53 PM
RS LOZWORTH
if its on steady it means that there is a detector fault if it flashes it means a red lamp has failed
Old Jan 2, 2008 | 06:54 PM
StephenC's Avatar
StephenC
..BS Motorsport..
learn something everyday,
Old Jan 2, 2008 | 07:38 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Tell us some more interesting facts please
Old Jan 2, 2008 | 07:45 PM
mercury grey minter's Avatar
mercury grey minter
I have a traffic light question.Some have cameras on top pointing at the traffic to catch red light jumpers,but some by me have cameras pointing down to the crossing which would only catch pedestrians.
WHY??????
Old Jan 2, 2008 | 07:51 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
ive always thought they worked on motion sensing not light sensing
Old Jan 2, 2008 | 07:53 PM
St3V3_C's Avatar
St3V3_C
Doesn' this go back years when heat sensors were used? The lights could trigger them
Old Jan 2, 2008 | 08:20 PM
focusv8's Avatar
focusv8
WHY??????
They aren't cameras, the ones on crossings detect pedestrians, (PUFFIN crossing).
http://en.wikipedia.org/wiki/Puffin_crossing
Traffic light cameras are on a separate pole from the lights.
Old Jan 2, 2008 | 08:38 PM
gkandr4ch's Avatar
gkandr4ch
Most traffic lights have those box sensors on the top of them. Got a set locally and I always flash them (normally at night) about 100 yards away and they change to green.
Old Jan 2, 2008 | 08:49 PM
focusv8's Avatar
focusv8
Have you tried NEVER flashing them and see if they still turn green.
Old Jan 2, 2008 | 10:03 PM
S1rst's Avatar
S1rst
I must admit im guilty of this too. Although i knew years ago that flashin doesnt do anything, i still do it out of habit at night if nothings about.
RS LOZWORTH, anyway if your a traffic light engineer mate, is there any chance you can come round this way and sort the timing out on 90% of the traffic lights cos there proper crap!
In fact sort londons centre out too mate cos there just as bad
Seriously though, whoever thinks up some of these sequences need shooting!
Old Jan 2, 2008 | 10:07 PM
mechanic28's Avatar
mechanic28
i think this rumar comes from the theory they detect police cars when they have there lights flashing that makes them change at least that what i heard
Old Jan 3, 2008 | 08:01 AM
RS LOZWORTH is 100% totally correct.
The lights are working EXACTLY AS HE SAYS.
The sensors are not CAPABLE OF SEEING LIGHT, they are MICROWAVE SENSORS on temp lights, they are tested with aboard run down a string towards them and they must react at the correct distance.
They do indeed go ALL RED, when they have detected no motion for a set period of time, then when motionis detected by MICROWAVE not LIGHT they run the CLEAR TIME first then go down to green on the appropriate side with the camera that has detected.
This is why some refuse to budge when a camera goes wrong on end will stay green whilst the other stays red.
Normal or permanent lights operate as he says, with induction loops BURIED IN THE ROAD about 10-20 feet before a junction, have a look easily sptted as they are odd angle lines covered over with smooth tar when installed.
Temp lights, roadworks etc, can have thier timings individually adjusted to suit each road for green time, clear time(all red) and red time.
There is a host of legal criteria for setting out temp lights, a lot not adhered to.
If ANY light in the world were activated by light, what di you think would happen in daylight as the sun is a little bit brighter than the average car headlight.
ps good explanation by RS LOZWORTH
Old Jan 3, 2008 | 03:59 PM
RS LOZWORTH
Thanks
Tabetha- how do you know all this ?!?!
Old Jan 3, 2008 | 04:11 PM
Luca's Avatar
Luca
Lukesville
well i still enjoy flashing and thinking it changes for me
Old Jan 3, 2008 | 04:28 PM
RS LOZWORTH
lol you keep doing it, but if the police c u it 3pts and a nice fine! DOH!
Old Jan 3, 2008 | 04:45 PM
cossiegreg1's Avatar
cossiegreg1
HOW?? it aint illigal to flash your lights.
Old Jan 3, 2008 | 04:48 PM
RS LOZWORTH
imagine flshing you lights like crazy at a junction and some one thinks that you are giving way to them- crash! plus you are meant to use flashing like a horn- to make people aware that you are there, try explaining that to the police, sorry officer i was trying to make the lights change
Old Jan 3, 2008 | 05:00 PM
S1rst's Avatar
S1rst
Sorry officer, i was making the traffic lights aware of my presence!
Old Jan 3, 2008 | 05:01 PM
S1rst's Avatar
S1rst
It wont be illegal though surely. If people choose to take it as a giving way flash without being sure its clear, then thats their fault.
Old Jan 3, 2008 | 05:11 PM
RS LOZWORTH
you probably would be able to explain your way out of it but i have heard stories of people getting done for it
Old Jan 3, 2008 | 07:27 PM
Bullett's Avatar
Bullett
tbh i know everyone over here flashes to say they are letting theother person go but every other country does it to say they are coming its thier right off way.
as for the lights.the set near my work are shit.i have to turn right but sometimes i can be sat there while it lets every other coont go 2 or 3 times before its my turn
Old Jan 3, 2008 | 08:53 PM
Oranoco's Avatar
Oranoco
No it doiesn't what happens is you flash your lights like a goon and drive over the traffic loop and as no other traffic is detected on the other approaches it then goes green and you think flashing your lights did it.
I work as a lighting and signing engineer in Hertfordshire and the signals engineers work in the same office. I can 100% assure flashing your lights does nothing
Old Jan 3, 2008 | 09:00 PM
SS1's Avatar
SS1
Oranoco
with out reading all of the above dont the wires in the road pick up your engine running some how via magnetics a pulse or something
Old Jan 3, 2008 | 10:08 PM
Neil S's Avatar
Neil S
No, the presence of a large metallic object (your car) alters the inductance of the loops, which is being monitored by the Traffic Signal Controller.
Neil.
Old Jan 3, 2008 | 10:17 PM
SS1's Avatar
SS1
cheers
Old Jan 3, 2008 | 11:22 PM
addiction's Avatar
addiction
I work with temporary traffic lights nearly every day and it amaze's me how many people actually think that flashing your lights will make them change!!!
Old Jan 4, 2008 | 12:07 AM
dave_20's Avatar
dave_20
i install traffic lights have done for a few years now and flashing at them dose not make them change lol
RS LOZWORTH who do you work for mate?
pm me if you want
