GPS Timing Gear Vs Timing at the Pod ?
Old Oct 27, 2007 | 01:02 PM
neilm's Avatar
neilm
Default GPS Timing Gear Vs Timing at the Pod ?
Guys
We had a Thrash yesterday at Brunters and they were using the in car, GPS receiver on the roof to do the timing.
How accurate is this compared to the more traditional timing set ups you get at drag strips ?
Old Oct 27, 2007 | 01:35 PM
JonnyBravo's Avatar
JonnyBravo
Santa Pod is VERY accurate I believe
It must be considering the drag series they hold there
Old Oct 27, 2007 | 03:45 PM
TiB's Avatar
TiB
The time will be pretty damned close but the terminal speed will read higher on the gps due to it reading actual speed at the qtr.. whereas pod measures the average speed of the last 66' or so.
As an example... on gps i got 133 terminal speed and with the same spec i got 129 at pod.
Lee
The Underdog
29
Sep 7, 2015 09:49 PM
jamie956
Sep 1, 2015 10:50 AM
YODI
Aug 30, 2015 01:12 PM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 8, 2015 07:12 AM
