any info on how easy it is to put a red top turbo in a 51reg
hi am thinking a bout putting a red top turbo lump in a 51reg corsa has any one on here done it before and wats the hardest part of doing it any info would be great ...thanks
Corsa C shape I take it? (ie not the original shape that replaced the nova?)
Not that trivial a job, it goes into the B really easy, but the C you have to start messing around retaining the original ECU to run the clocks etc as its all integrated on a CANBUS system.
A Z20LET motor might be simpler, but Ive not done a Corsa C so havent got an direct experience like I have with the B and the Nova.
www.VauxSport.com for more info mate
Not got any info on the conversion but if you want it to be worth anything in terms of resale then i go with the z20 let,
I personally wouldn't buy a new ish car with an old engine plus from what i've seen with the z20's you won't go far wrong tuning wise either.
cheers lads il be donig it soon as my escort is going....some lad said i only need the engine loom and the ecu from the cav turbo. also wat drive shafts and fuel pump would i need thanks
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
