PF Sparkys!
Old Oct 26, 2007 | 08:35 PM
Rippers's Avatar
Rippers
Monte Geek
Default PF Sparkys!
The old dear asked me to change the fan light in her bedroom for a normal light fitting, never had a problem before with wiring but this one was slightly different and rather then blow up her house I thought I'd ask you guys for a pointer
I removed the fan light. It was wired so you could turn the light on and off at the light switch but also you can turn the fan on or off from a pull cord on the fan whether it was switched on or not from the light switch
and was left with this
The black wire on the far right had a bit of red tape on it. So how do I wire up a simple light fitting to it please
Cheers guys
Old Oct 26, 2007 | 08:40 PM
St3V3_C's Avatar
St3V3_C
Use 2 & 3
Old Oct 26, 2007 | 08:41 PM
St3V3_C's Avatar
St3V3_C
3 is live BTW, not that it really matters...
Old Oct 26, 2007 | 08:43 PM
danneth's Avatar
danneth
TORQUE!
swop the red tape for brown sleeving just to make a really good job of it
Old Oct 27, 2007 | 01:34 PM
Rippers's Avatar
Rippers
Monte Geek
Cheers I've have a go tonight
Old Oct 27, 2007 | 03:56 PM
rssteve's Avatar
rssteve
is there any earth cables there?
Old Oct 27, 2007 | 04:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
why don't you wait till the morning? when you can actually use the light from outside and not depend on your old dear holding a wobbly torch so you can see what you are doing
Old Oct 27, 2007 | 05:09 PM
grsford's Avatar
grsford
1,live loop 2,neutral 3,switch line as said above conect into 2 and 3
Old Oct 27, 2007 | 11:25 PM
col cos1's Avatar
col cos1
dont fukn touch it ur no a spark....ur doing me out of my new front pads...lol
Old Oct 27, 2007 | 11:34 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
So we're saying 1 is live, 2 is neutral, and 3 is switch live.
So why is 2 linked to 1?
Old Oct 28, 2007 | 09:49 AM
focusv8's Avatar
focusv8
It isn't linked
Old Oct 28, 2007 | 02:29 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
Don't put any brown tape on as it is wired to a previous version of BS7671
Old Oct 28, 2007 | 02:30 PM
foreverwhite's Avatar
foreverwhite
im shit with stuff like this...so would make a REALLY wank sparky lol
and unless i had 1000% confidence in my work i wouldnt want to risk burning my house down etc
jc1989rs
Sep 18, 2015 07:05 PM
sparkys2turbo
16
Jan 5, 2012 03:29 PM
sparkys2turbo
Jul 29, 2011 12:41 PM
sparkys2turbo
May 16, 2010 12:17 AM
sparkys2turbo
May 9, 2010 10:00 PM
