cylinder head thickness
Old Oct 25, 2007 | 10:20 PM
col cos1's Avatar
col cos1
Default cylinder head thickness
i know what the measurments should be but is the small nib at the bottom of the thermostat housing the limit indicator type bit,when you know its had its last skim?
ie if its flush thats it it cant be skimmed again?
Old Oct 25, 2007 | 10:25 PM
dave cos4x4's Avatar
dave cos4x4
the brass bit.
that can be knocked in if you hit it.
the head thickness will tell you if it can/should be used not a little brass plug thingy
Old Oct 25, 2007 | 10:40 PM
col cos1's Avatar
col cos1
na not that dave
was just looking at the head i bought and the bottom of the mount holes for thermo is skimmed flush??????????????????
Old Oct 25, 2007 | 10:48 PM
dave cos4x4
ah....not really noticed then tbh.
i always look at the bit where the ect/blue temp sensor is bolted to,the mount that the sensor is bolted to is not skimmed but the head is,if you look at the two you can see the difference in then and can get an idea from that.
well thats what i look at anyway.
can just look how close the valves are to the surface too.
Old Oct 25, 2007 | 10:51 PM
col cos1's Avatar
col cos1
cool
dropped car off to get the new brakes fitted tonight dave
looking forward to getting it back
Old Oct 25, 2007 | 11:04 PM
dave cos4x4
could you not fit them yourself.
be well better,well i hope so after the money you must have spent on them,hope you can tell the difference.
Old Oct 25, 2007 | 11:06 PM
xr4x4rs's Avatar
xr4x4rs
ive never seen a head yet with the blue water temp housing not machined
my head has had never been skimmed until i had it done and that housing was machined
Old Oct 25, 2007 | 11:07 PM
col cos1's Avatar
col cos1
i could but knowing my luck id get it all fitted and not have the right flexis or something and the car be stranded outside my house
as its kept at my folks garage
my mates a great mechanic and does most of the work on my car and dont cost much so cant complain
Old Oct 25, 2007 | 11:11 PM
dave cos4x4
well they are lazy then as the housing comes off with the 2 allen key bolts and you even get a gaslet in the head set for it.
the heads i have had,the housing has never been skimmed.
lee2cossies's Avatar
lee2cossies
How about these ferriday decompression plates?are they any good? i recently put and engine together for someone with one and i aint yet tried it.
dave cos4x4
col cos1
might aswell let him do it then.
Old Oct 25, 2007 | 11:12 PM
dave cos4x4
don't personally know anyone who has used one.
Old Oct 26, 2007 | 12:08 AM
abdr500's Avatar
abdr500
lee2cossies
they do drop the comprison down but its also the squwise area that is most affected
Nov 1, 2015 06:53 PM
