Solid Engine Mounts? Solid beam/diff mounts?
Old Oct 25, 2007 | 06:26 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default Solid Engine Mounts? Solid beam/diff mounts?
Does anyone run solid engine mounts in their cossie?
If so how much extra vibration & noise do you get over uprated type?
Also same applies to rear diff mount, I'm thinking of mounting the beam soldidly....has anyone doe this and again what are the disadvantages.
Dan
Old Oct 25, 2007 | 06:28 PM
gus's Avatar
gus
i have solid mounts to go on my s1 when ready, if tooo harsh i will put the normal vibratechnics back on
Old Oct 25, 2007 | 06:39 PM
SillyFezzaMk1
Rubber Rhino Crew
I'm just of the opinion that if the vibrations arent going to be that bad then I can save probably over 200 quid by making my own mounts at work in machine shop...money to spend elsewhere on ym project.
Dan
Old Oct 25, 2007 | 07:47 PM
SillyFezzaMk1
Rubber Rhino Crew
I'm also worred about harmonics causing failure of the mounts, engine arms or worst case the block.
Dan
Old Oct 25, 2007 | 07:53 PM
ECU Monitor Enthusiast
DONT use solids... You will regret it !
Had them in my RS2000 mk2 turbo and they were removed after 1 day !
Old Oct 25, 2007 | 07:56 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
As above! I can do mounts at reasonable money
Old Oct 25, 2007 | 07:59 PM
SillyFezzaMk1
Rubber Rhino Crew
Fairy muff.....I think I'll give the solid engine mounts a miss...I was kinda hoping someone would convinve me to do it as i'd like to try it but If its been done and not practical then i'll fuck the idea off.
SO rear beam solidly mounted...good idea or bad? LOL
Old Oct 25, 2007 | 08:01 PM
Martin-Hadland
The beam will be ok but will transmit more noise.
SillyFezzaMk1
Rubber Rhino Crew
Can you get away with the one mount uprated as i've heard only one of them ever fails (can't recall which side).
And how much is reasonable?
Dan
Old Oct 25, 2007 | 08:02 PM
Martin-Hadland
Dan
Drivers side fails but it's worth doing both..
Old Oct 25, 2007 | 08:35 PM
Tev's Avatar
Tev
Im runnin solid diff mount and my rear beams solid mounted, as martin says it transmits more noise but other than that its been fine,
Old Oct 25, 2007 | 08:43 PM
SillyFezzaMk1
Rubber Rhino Crew
How did you solid mount the beam? I was thinking of leaving the OE ford bushes in and just solid mounting the diff but concerned it might put too much stress through diff casing and mount.......I could use poly bushes or if fabricate some sort of solid mount where the bush is removed from.
Dan
Old Oct 26, 2007 | 06:06 PM
Tev's Avatar
Tev
Dan
Speak 2 marko polo, i managed 2 pick up a set of solid donuts of ebay
They work really well,
As 4 solid mountin the diff, i had a really simple T bracket made up, got rid of the shaged old bush n just simply bolted it all up, its been fine ive done over a 1000 miles with no problems, a couple of hard launches, can email u some photos if u need, its a cheap option, well worth it
Old Oct 26, 2007 | 06:35 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i use the solid beam mounts on the road/track..... doesnt make to much difference noise wise compared to the poly ones really. i use a standard diff mount rather than a poly/soild one , apparently using the two together is noisey!
transforms the handling btw top mod
Old Oct 27, 2007 | 07:52 PM
Red16's Avatar
Red16
ive just changed my standard engine and gearbox mounts on the evo for a set of Powerflex poly ones, and the in car vibration has definitely increased a lot, but its only noticeable at idle and when pulling away. I also fitted a twin plate clutch at the same time so dont know if the clutch is contributing towards the higher in car vibrations being felt.
Old Oct 31, 2007 | 09:05 PM
SillyFezzaMk1
Rubber Rhino Crew
Dan
Are them solid mounts on a car at present? If not can you do me a drawing with dimensions so I can have some made please mate!
Failing that I'll have to wait and search ebay for some.
Dan
Old Oct 31, 2007 | 11:10 PM
Tev's Avatar
Tev
U have pm fella
bigluke200
14
Sep 2, 2015 10:35 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
