Dump Valve on a diesel?
Old Oct 25, 2007 | 01:26 PM
Aaron1204's Avatar
Aaron1204
Default Dump Valve on a diesel?
I didn't think you could?!
Theres an as in the for sale secton for a Pug HDI with a dump valve...
Now I don't want to, as I imagine it would sound poo but can you do that to any diesel then? like a focus 1.8 tddi?
Old Oct 25, 2007 | 01:31 PM
gingeRS's Avatar
gingeRS
yup
Old Oct 25, 2007 | 01:47 PM
Aaron1204's Avatar
Aaron1204
Originally Posted by gingeRS
yup
With the same kind of dump valve that you use on a petrol or one specific to a diesel? I didn't think there was enough pressure going through the turbo
Old Oct 25, 2007 | 01:52 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
http://www.dervdoctor.co.uk/
Old Oct 25, 2007 | 01:53 PM
gingeRS's Avatar
gingeRS
yup
most diesels run higher boost pressures than petrol engined vehicles nowadays
Old Oct 25, 2007 | 01:56 PM
percybigun's Avatar
percybigun
Twistin me melon man
i had one on my 1.8TD mondeo and it sounded pretty good. you need a twin piston one or it will sound awful.
it might not be serving a purpose but neither is alot of the mods we put on our cars. its a bit of fun though innit!
i had mine so i could turn it off on the throttle switch, when it was turned off the turbo didnt seem to spool up as quick between gearshifts as when the DV was in use. might have just been me but that was my experience. it was running 19PSI of boost.
also on mine it had a big bore exhaust and was fairly tuned up so it didnt sound very diesel-ish anyway, it was quite beefy. on a normal tractor sounding diesel a dump valve would probably sound a bit gash.
Old Oct 25, 2007 | 03:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
how do you fit a dump valve to a diesel then? you can't as it's got no vacuum
has it?
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
