Teaser for the Techies
Old Oct 25, 2007 | 10:48 AM
ian sibbert's Avatar
ian sibbert
Default Teaser for the Techies
http://www.forddoctorsdts.com/quizze...alAptitude.php
We managed 88% on our first go......
Old Oct 25, 2007 | 11:02 AM
lead_foot's Avatar
lead_foot
is awesome
96% first time:
Old Oct 25, 2007 | 11:03 AM
Jamz's Avatar
Jamz
got bored at question 7
Old Oct 25, 2007 | 11:06 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I got 88% as well, although that should have been 90 as one was a mouse error, I meant to click one box and clicked the other, LOL
Old Oct 25, 2007 | 11:09 AM
ian sibbert
Any thoughts on question 48?
It's caused some controversey.....
Old Oct 25, 2007 | 11:11 AM
Chip's Avatar
Chip
I dont see why it would cause controversy, without any doubt at all the answer they have said is correct is exactly correct.
The piston drops, the pressure in the cylinder decreases and therefore the pressure from the atmosphere pushes air into the cylinder.
Couldnt be more straightforward IMHO, its just basic Physics.
Old Oct 25, 2007 | 11:17 AM
Chip's Avatar
Chip
PS
Of the ones I got wrong, the only one that when I read back I dont go "oops, should have read it properly not answered them all really quick by browse reading" is 7
To me that picture of C, is reverse, one gear is turning the other one backwards.
In fact TBH A and B are also reverse gears IMHO, just ones with a ratio as well as a change of direction.
ian sibbert
I have an office full of fridge engineers here all agruing that it's suction...
Old Oct 25, 2007 | 11:21 AM
Chip's Avatar
Chip
Well all of them would have failed GCSE physics then
Given that they are fridge engineers in particular, im amazed that they would make that mistake, as pressure is like HEAT, it is only viewed as moving from a high state to a low state.
Ie you dont add coldness to an item, you take away heat from it, likewise with pressure and airflow, if it moves from B to A then you dont say it gets sucked in form A to B, it gets blown from B to A.
Old Oct 25, 2007 | 11:32 AM
Garage19's Avatar
Garage19
I think what you are getting at is the pressure drop caused by the exhaust gas leaving the cylinser and the air sucked in on valve overlap?
Old Oct 25, 2007 | 11:33 AM
Garage19's Avatar
Garage19
Oh just realised you are aguing over what suction is.
Chip's Avatar
Chip
no, they arent that clever, they are just saying the piston is causing suction I suspect.
Old Oct 25, 2007 | 11:34 AM
Chip's Avatar
Chip
Indeed
Old Oct 25, 2007 | 11:40 AM
St3V3_C's Avatar
St3V3_C
I got 90% and couldn't see my right / wrong answers?
I said suction though
What were the options on that one?
Old Oct 25, 2007 | 11:41 AM
ian sibbert
No, not being clever, just I had 4 of them with me this morning and 2 of them were arguing its the piston dropping that causes suction which pulls air into the engine....
Old Oct 25, 2007 | 11:42 AM
St3V3_C's Avatar
St3V3_C
the piston dropping causes a low pressure, atmosphere then pushes air in.
Chip's Avatar
Chip
no, the piston dropping causes a drop of pressure, which causes a pressure differential which results in the atmospere pushing air into the cylinder.
its semantics from an english point of view, but physics is very fixed on its opinion of what happens.
Old Oct 25, 2007 | 11:52 AM
-J-'s Avatar
-J-
i got 62% Which seeing as im Not technical in the least i didnt think was to bad
Old Oct 25, 2007 | 11:57 AM
Rippers's Avatar
Rippers
Monte Geek
64% I suck
Punkie's Avatar
Punkie
For Sale..Apply within.
66%
Not bad for a girl.
Old Oct 25, 2007 | 11:59 AM
ian sibbert
Chaps....I agree, and I got the fooking question right lol, they were berating me but I do remember it from a physics perspective, from my school days.....but when you get my age though remembering actually being at school is difficult....
Paddy's Avatar
Paddy
Legend
Originally Posted by Paul Ripley
64% I suck
Or do you blow?
Like the air into a piston?
Either way
I got 72% which is why I pay greasemonkeys to know this stuff. My mind is on higher things.
Old Oct 25, 2007 | 12:01 PM
kirstyKA's Avatar
kirstyKA
I got 58%
Old Oct 25, 2007 | 12:07 PM
RS500/364's Avatar
RS500/364
70% 370was thescore
Old Oct 25, 2007 | 12:10 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Got 84% I am not really that mechanically minded.
Mind you, most of it seems to be basic physics rather than mechanical knowledge per say.
Old Oct 25, 2007 | 01:55 PM
Diamonds.'s Avatar
Diamonds.
78% and thats the first time in ages ive used my brain
Old Oct 25, 2007 | 02:21 PM
alistairolsen's Avatar
alistairolsen
94%, fucked a couple of them by not realising theyd changed the masses in the drawings
In physics, suction and centrifugal force do not exist
Old Oct 25, 2007 | 02:47 PM
AlexF's Avatar
AlexF
Its the piston that creates a change in volume.
It is a pressure difference that fills the cylinder.
Old Oct 25, 2007 | 02:50 PM
foreigneRS's Avatar
foreigneRS
Testing the future
92% good quiz though ian
thought question 7 was confusing as per chip
made a wrong click on 17 (25 kg instead of 50)
couldn't be arsed to think about question 44 properly by the time i got there
couldn't see how getting 3 wrong answers would give 92%, but as there is 2 wrong on Q7 it must count as 4% - but it's not possible to get only 1 out of 4 wrong
Old Oct 25, 2007 | 03:03 PM
user 769729789's Avatar
user 769729789
72%, im chuffed as i couldnt tell you one end of a screwdriver from another!
Old Oct 25, 2007 | 03:12 PM
dojj's Avatar
dojj
Resident Wrestling Legend
answered all the questions and the fuckers crashed on me and sent back to question 7 with an empty page
Old Oct 25, 2007 | 03:30 PM
Nick.'s Avatar
Nick.
80%.. not bad for a retarded 18 year old
Old Oct 25, 2007 | 03:37 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
94%, got 3 wrong...ironically 3 I thought were easy obviously not.
Old Oct 25, 2007 | 04:06 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
82%
Old Oct 25, 2007 | 05:12 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
been on british rally ian.
Old Oct 25, 2007 | 05:41 PM
ian sibbert
Saw it on there and thought it was worth sharing......
Last time I did one like this was about 15 years ago...lol...with pen and paper.....
Old Oct 25, 2007 | 05:52 PM
Micky The Finn
Former Sponsor
the thread on there is rather different to here ian,some real clever fookers in the rallying world.
