Mondeo - Zetec 1.8 - Plug 4 missing during idle
Old Sep 27, 2007 | 09:35 PM
sdr's Avatar
sdr
Default Mondeo - Zetec 1.8 - Plug 4 missing during idle
Hello Folks, need to pick your brains again please.
My girlfriend has a 1997 1.8 mondeo, 115ps, with 48000 miles on it.
tonight I jumped in, and found it very lumpy at idle, but normal to drive.
Taking a closer look, I've traced the problem to number 4 plug. It was black and oily, & fouled pretty bad. Looking down the plughole, the cylinder top is very oily.
The car misses during idle, however up the revs, past 1000, the engine seems to stop missing, and when driving it, its fine and appears to use all 4 plugs normally.
I've tried changing the plug leads, no difference
I've changed spark plugs 3 & 4 around (having no spare plugs) I'll check number 4 tomorow night.
The only other thing I can think could be the DIS / ignition box? but I dont have a spare or donor car to rob bits off
Does anyone have any other ideas??????
Thanks
CHRIS
Old Sep 28, 2007 | 05:53 AM
The coilpack is paired 1+4, 2+3 so sweap the leads at coilpack 1+4 around to see if problem shifts to 1, some odd times the coilpack output terminals go bad, but ones side still works perfect.
Old Sep 28, 2007 | 09:00 AM
sdr's Avatar
sdr
Cool thanks Tabetha, I'll try that
CHRIS
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
