Temp Guage Is it wrong??
Old Sep 17, 2007 | 05:36 PM
dazrsturbo's Avatar
dazrsturbo
Default Temp Guage Is it wrong??
My temp gauge in the s2 looks like there might be something wrong with it?? When i turn the engine off it drops right down (see picture) should it do this or should it sit at the bottom of the gauge where the cold bit starts?? help!
Old Sep 17, 2007 | 10:49 PM
©hatter Box's Avatar
©hatter Box
the temp sender in head you need a new one
Old Sep 17, 2007 | 11:00 PM
user 769729789's Avatar
user 769729789
Assuming it works fine when your driving, then whoever has changed the dials had put the needle back on wrong.
You need to take the actual needle off and push it back on at the right angle.
Old Sep 18, 2007 | 09:10 AM
turbo's Avatar
turbo
mine used to sit just above that in my old rs turbo but when i used to turn the ignition on the needle used to rise to just under the first box ( cold ) & when warm bang in the middle of the gauge. if you got lockwood or the plazma dials in your car then the needle would have not been taking off to fit these dials as the dials go over the needle's.
Old Sep 18, 2007 | 09:11 AM
turbo's Avatar
turbo
oh forgot to say if the fan cut's in when the needle is in the middle of the gauge then it's doing its job just fine ( the needle that is ) hope this helps.
Old Sep 18, 2007 | 06:46 PM
dazrsturbo's Avatar
dazrsturbo
thanks for the help guys!
Old Sep 18, 2007 | 11:29 PM
Grandad racer's Avatar
Grandad racer
pull the needle off, switch on the ignition,put the needle back on the start of the black cold box, easy!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
DavidK
Sep 27, 2015 02:55 PM
