MINI MEGASQUIRT FOR ZETEC OR RS TURBO
Old Sep 10, 2007 | 10:49 PM
banhambuilt's Avatar
banhambuilt
Default MINI MEGASQUIRT FOR ZETEC OR RS TURBO
a bit of info needed please
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=007
this seems cheap for an aftermarket ecu,are they any good?
it says it will control boost to 21psi,but can be up-graded if needed,it will also do n/a
anyone had much experience with megasquirt?
thanks guys
dave
Old Sep 10, 2007 | 11:06 PM
robrs2's Avatar
robrs2
It good kit. I have a V2.2 its the older and bigger ecu. Look on the MS site www.msefi.com Its not a simple fit kit, but with a bit of reading and testing it works ok. One downside is the lack on base maps. But if fitted with a wideband or narrowband (limited) the system can self learn a rough base map.
Going to be fitting One on my BOB power sierra soon.
Old Sep 10, 2007 | 11:37 PM
turboben's Avatar
turboben
i looked into this as well but was told to stick to the 2.2 or the 3 by a bloke that maps these as the v2.5 is not actually assembled by megasquirt but by mtech or someone like that and it is wired up slightly different to the conventional 2.2 or 3
plus all the extras add ons are not as good as they sound as they dont work 100% they are basically a poor mans management more sorted to a kit car for example and was told to stick to my ford edis management as more people know about them it is more reliable and easier to fix
so i have been told
Old Sep 10, 2007 | 11:42 PM
robrs2's Avatar
robrs2
Yep go for the V3
Old Sep 11, 2007 | 06:41 AM
Alex_86's Avatar
Alex_86
from the US much cheaper!
Old Sep 11, 2007 | 06:58 AM
JesseT's Avatar
JesseT
295£ is a bit too much. Not that it's not worth it, but you can get the good old v2.2 for less than half of that.
Old Sep 11, 2007 | 07:10 AM
robrs2's Avatar
robrs2
Try Bill Shirvington got mine from him
Old Sep 11, 2007 | 08:22 PM
turboben's Avatar
turboben
http://www.megatuned.com/
Old Sep 24, 2007 | 03:44 AM
Jac's Avatar
Jac
Default Re: MINI MEGASQUIRT FOR ZETEC OR RS TURBO
thanks guys
dave
We gently introduced this one a while ago having supplied one or two to Kit Car owners, whom needed three on- board relays for their typical Zetec instalation, and were not impressed with PC World Computor Printer Plug, that it is standard fare from MegaSquirts built in the good 'ol US of A...
The eBay listing was a toe in the water, before it is launched formaly latter in the year...
It is basicly a smaller foot print, V2.2, in a waterproof case, useing an automotive ECU Connector plug and Socket, AMP Seal.
We have had over 400 MegaSquirt ECU's though our workshop in the last Two Years, and this is the best Meagsquirt variant we have seen, and uses the tried and and tested Ford EDIS system, which rarely gives the AA man a problem.
For more info go to www.mtechautomotive.co.uk
The on-line quotation service will quickly show if your car is suitable, and how much it will cost, including all Option, Upgrades.
NB We will upgrade or repair ANY derived Megasquirt product.
If it was built by Mtech it will be done free of charge, as will still be under our TWO YEAR WARRENTY (Transferable)
Alternativly you could just give us a call and ask for Matt...
For base map requests, go to www.megasquirtmaps.com and post a request...
Old Jul 19, 2008 | 12:05 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
ok now im baffed i have a v3.0 ecu should i sell and get a 2.2 wid edis??
Old Jul 19, 2008 | 12:09 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
i got V3 for zetec turbo,its best one ive been told for the job!
robnock
21
May 13, 2019 05:29 PM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
Red_bull
Aug 25, 2015 06:27 PM
