Tapping noise from top end
Old Sep 4, 2007 | 10:01 AM
RickyLee53's Avatar
RickyLee53
Default Tapping noise from top end
My mates just bought an RST and its broke, no suprises here
Anyway, Its a pretty standard CVH, the tapping sounds to be coming from top end of piston no. 1. Is there a known fault for this? Sure there is? If so what's the fix? Have they got lash adjusters/tappits? that can be cleaned or replaced.
Its got an uprated cam and vernier, the pulley hasn't moved and the problems just started. So its nothin to do with clearance etc.
Old Sep 4, 2007 | 10:12 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Re: Tapping noise from top end
Theres the clue for me.
I would bet its run a cam lobe off.
Old Sep 4, 2007 | 10:50 AM
matt p's Avatar
matt p
What my kent cam is now broke after 60 miles??
Old Sep 4, 2007 | 11:10 AM
RickyLee53's Avatar
RickyLee53
Care to explain a little please
Do they suffer from lack of oil or something?
Old Sep 4, 2007 | 11:19 AM
Christian and Beccy
#1 in Spelling Club
UK Cam manufacturers are outsourcing cam blanks and particularly followers from China and India. In an engine that doesn't have a particularly great valvetrain design and will run a cam off in the blink of an eye, giving it any greater opportunity to do so, will be fatal for the cam.
Newman make their own stuff, but sadly that means going over to solid lifters. While this is a far better option for performance and eliminates the high-end missfires etc associated with 'other' manufactuers cam kits, it isn't an easy option to fit.
Old Sep 4, 2007 | 12:48 PM
RickyLee53's Avatar
RickyLee53
Whats the price and where can u get them?
Many thanks.
Old Sep 5, 2007 | 10:24 AM
RickyLee53's Avatar
RickyLee53
Right, its 115, for the 276 cam and Ł128 for the lifters.
The cam i've took out hasn't worn 2 badly at all though, so i have a feeling its the lash adjuster.
Could i clean them and try it out?
Could there be a blockage in the oil gallery? How would i go about cleaning this out.
Old Sep 5, 2007 | 05:57 PM
Billy_RS's Avatar
Billy_RS
Could well be the cam.
I took my old piper out, looked a the lobes and thought to myself "i've only had this a couple of months......shit!"
If not, then check thne usual suspects.
Low on oil
Wrong oil (Too thin)
Etc etc
Old Sep 6, 2007 | 05:45 PM
base190380's Avatar
base190380
try diconnecting spark plug lead on no1 cylinder, then start it, yes it will run rough but has the noise gone?
Old Sep 12, 2007 | 03:54 PM
RickyLee53's Avatar
RickyLee53
I've got a newman cam and solid lifters. Does any1 know the correct, valve clearance for both exhaust and inlets.
Many thanks.
Old Sep 12, 2007 | 04:52 PM
Moonie's Avatar
Moonie
I would also have a look at the exhaust manifold gasket. If i's leaking the noise can be very similar to a noisy lifter.
Old Sep 13, 2007 | 10:08 PM
bonus_boy's Avatar
bonus_boy
i brought some 10w/40 castrol oil for mine and since ive used it its started to tap from the top end!
obviously is this down to the oil or just timing for the cam and lifters wanting to be changed
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bezzy41
Aug 3, 2015 10:31 AM
