Setting EFi CO Pot
Old Sep 4, 2007 | 08:09 AM
hardhitter's Avatar
hardhitter
Default Setting EFi CO Pot
Can anyone tell me what resistance the CO Pot should be set to ? and what pins do you measure it over.
Thanks
Old Sep 5, 2007 | 05:46 PM
Billy_RS's Avatar
Billy_RS
If you have done an efi conversion and need this setup, i would advise you take it to a tuner for a setup and they will adjust the co as part of the service (i would expect!)
Old Sep 5, 2007 | 07:06 PM
BRAMMER's Avatar
BRAMMER
Correct info above my mate had a escort efi turbo and his Co was all over the place, get it toa tuner and they will set it.
Old Sep 5, 2007 | 10:04 PM
Chris69's Avatar
Chris69
you need to go to a tuner or at the very least to a friend or garage that has a wideband lambda to insure you not too rich or lean
Old Sep 6, 2007 | 05:39 PM
base190380's Avatar
base190380
hi guys, ive done a efi conversion turbo setup and my car was a 1.6i efi non turbo. does the co have to be adjusted now or would it be the same on the standard setup. my car keeps running a tad rough and backfires as though its really rich. it never doen this before!
Minirotty
11
Sep 15, 2015 10:16 PM
locum8
Sep 14, 2015 08:45 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
