Few 4x4 cossie bits req'd
Rubber Rhino Crew
After an alternator for a 4x4 saphy engine.
Also require a Front ARB mounting bracket, had a nightmare with the nut breaking off inside the chassis leg; saw red and ground through the bastard..If anyone has one or a pair they wanna sell lemme know it saves rooting arround in scrappers for them.
Uprated 4x4 engine mounts
Steel front diff sandwich plate (the type that goes inside diff to strengthen casing)
4x4 cossie ignition amp
Vernier cam pulleys (prefferably black but will consider any)
2wd Intercoolers (going to weld a few together custom for my project)
What you lot got then? LOL
Dan
Dan
Engine mounts - Vibratechnics ones and matching gearbox mount if interested
Alternator off a 2.9 24v that originally came off a 2.8 - might fit, cheap if it does, only round the corner in coventry.
DixieTheKid
Jul 23, 2023 10:16 AM
jason_nike
Aug 18, 2019 10:53 AM
bump
