smoking !!!!!
Old Aug 30, 2007 | 05:38 PM
ginner s2's Avatar
ginner s2
Default smoking !!!!!
hi my s2 has started 2 smoke real bad only on start up .cud it be the turbo or is it more like 2 be the piston rings.
Old Aug 30, 2007 | 05:43 PM
antony215's Avatar
antony215
Escort Rs Turbo
What colour is the smoke???
Old Aug 30, 2007 | 05:46 PM
ginner s2's Avatar
ginner s2
white
Old Aug 30, 2007 | 05:50 PM
antony215's Avatar
antony215
Escort Rs Turbo
White is normally head gasket. Blue/grey is normally turbo/rings
Old Aug 30, 2007 | 05:53 PM
ginner s2's Avatar
ginner s2
.thanks bud.
Old Aug 30, 2007 | 05:56 PM
antony215's Avatar
antony215
Escort Rs Turbo
Best to do a compression test on it mate
Old Aug 30, 2007 | 07:17 PM
ginner s2's Avatar
ginner s2
wot will that show.wherever bottom end is on its way out
Old Aug 30, 2007 | 11:37 PM
antony215's Avatar
antony215
Escort Rs Turbo
It will tell if you have low compression e.g if the head gasket is gone or it can indicate a worn bottom end but if yours is kicking out white smoke its more than likely head gasket. Do it use alot of water or get hot quick??
Old Sep 3, 2007 | 09:42 PM
lewis_lisa's Avatar
lewis_lisa
check your oil m8 see if its got water in it or oil filler cap as it prob will have a mayonaise type stuff on it
hope you get it sorted
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
