Flywheel bolt holes??
Old Aug 27, 2007 | 03:15 PM
antony215's Avatar
antony215
Escort Rs Turbo
Default Flywheel bolt holes??
Ive got a small amount of oil coming from one of the bolt holes when the engine is at an angel (the flywheel is off with no bolts in the holes) it's not coming out when the engine is at the normal angle in the bay just when it's let down and it's at an angle when the flywheel end is pointing towards the floor is this normal or has a seal gone
Old Aug 27, 2007 | 09:02 PM
scholes's Avatar
scholes
sounds like the crankshaft oil seal
Old Aug 27, 2007 | 09:49 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
the flywheel holes in the crank go straight into the engine, if the bolts are out then oil will leak out if the engines on the piss, dont sweat it
Old Aug 28, 2007 | 10:05 AM
antony215's Avatar
antony215
Escort Rs Turbo
Thats what i was thinking/hoping
Old Aug 28, 2007 | 10:19 AM
SafeChav's Avatar
SafeChav
You silly twat
Maybe you can help me while i'm here - ive got this bottle of coke, but if i turn it upside down without the lid on it spills out everywhere
Old Aug 28, 2007 | 10:26 AM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah thats an easy one to sort put the lid back on and drill a hole in the top
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
