std zetec rods
Old Aug 26, 2007 | 04:35 PM
juffer's Avatar
juffer
Default std zetec rods
hi,
thinking of doing a conversion and cant find out what the standard zetec rods will take (psi). The search mentions about the pistons but not rods. Im hoping to go down the route of using c20let calibra pistons. can anybody help me with information.
cheers geoff
Old Aug 26, 2007 | 04:41 PM
LEE-RS's Avatar
LEE-RS
Custom
standard rods will take 300 with arp rod bolts but not worth taking the risk when you can buy steel rods for around £160 from the states
Old Aug 26, 2007 | 05:42 PM
juffer's Avatar
juffer
what psi can the c20let pistons take and what power figures would be reached with a sensible but standard build (ish) head work ect.
Old Aug 26, 2007 | 05:47 PM
Badman38's Avatar
Badman38
i ran 24 spi with a t34 and 19 psi with a gt 25/40r they are forged pistons so with the right mapping you could run 30 psi if you had stronger rods, 310 bhp with those pistons.
thanks
sean
Old Aug 26, 2007 | 05:53 PM
juffer's Avatar
juffer
i currently have a 1.9 power engeneering build (the 1.8 cvh crank version) what power figures is this engine capable off with management?
Old Aug 26, 2007 | 06:01 PM
Badman38's Avatar
Badman38
i use to run the same 1.9cvh with a decent cylinder head 300bhp the engine is quite strong.. weakest part is the cylinder liners i split mine using loads of nitrous.
thanks
sean
Old Aug 26, 2007 | 06:17 PM
juffer's Avatar
juffer
hi sean
what psi was you running, have you ever run a zetec turbo if so how would you compare them.
Old Aug 26, 2007 | 06:21 PM
juffer's Avatar
juffer
'have you ever run' sorry missed your earlyer post
Old Aug 26, 2007 | 08:27 PM
Badman38's Avatar
Badman38
hi sean
no never run a 16v zetec just the zetec bottom end the zetec will be an all round better engine if you spend your money on the right parts.
sean
Old Aug 26, 2007 | 08:33 PM
juffer's Avatar
juffer
do you remember what boost you was running on the power engineering build or the capability that it can take. i phoned P.E and they was not all that helpful
Old Aug 26, 2007 | 08:39 PM
LEE-RS's Avatar
LEE-RS
Custom
the 1.9 cvh rods are only good for 260 ish bhp and steel rods for them are £700+
with the zetec block you can get forged pistons and steel rods for £500
Old Aug 26, 2007 | 08:53 PM
juffer's Avatar
juffer
hi lee are you talking about the american tall block engine. when i rang P.E they would not tell me what rods they were due to the engine being copied. its a 1.6 boared out with a 1.8 crank. i done big end bearings about 6weeks ago and sent the big ends off to be matched and they came back as the same size as bearing used on a tryumph. any more help would be appreciated
juff
Old Aug 26, 2007 | 08:56 PM
Badman38's Avatar
Badman38
i ran 25psi on a t34 0.63 exhaust the engine is strong just make sure you get the car mapped too much heat will cause the liners to split.
sean
Old Aug 26, 2007 | 09:11 PM
LEE-RS's Avatar
LEE-RS
Custom
juff
depends if its a old pe 1.9 cvh or a newer type as the newer type are not so strong as there built at vulcan engineering
Old Aug 26, 2007 | 09:20 PM
Badman38's Avatar
Badman38
pe 1.9 1.8 cvh crank, triumph tr7 rods, merc mahle pistons.
Old Aug 26, 2007 | 09:24 PM
juffer's Avatar
juffer
yeah sean that sounds the one, is that the newer or older one
Old Aug 26, 2007 | 09:32 PM
LEE-RS's Avatar
LEE-RS
Custom
thats the older pe built one
Old Aug 26, 2007 | 09:41 PM
juffer's Avatar
juffer
has any one done a write up on this engine as i feel alittle blind not knowing any thing about it ie comp ratio
Old Aug 27, 2007 | 01:01 PM
Badman38's Avatar
Badman38
vulcan engineering done a write up years ago in classic ford mag i've got the mag laying about somewhere.
thanks
sean
ps i thought vulcan built all of pe 1.9cvh?
Old Aug 28, 2007 | 07:31 PM
LEE-RS's Avatar
LEE-RS
Custom
they did there own machine work untill about 9 years ago they also used to do good ported heads before vulcan took over doing the work
steven rw off here had a old power engineering ported head 1.6 cvh did 150 mph on 13 psi
Old Aug 28, 2007 | 07:36 PM
Alex_86's Avatar
Alex_86
link
and it it to the black top or to the silver one?
Old Aug 29, 2007 | 09:23 PM
Badman38's Avatar
Badman38
link
the rods at meant for the black top but you can sue them in the sliver top like i have.. i bought my eagle steel rods from here www.nolimitmotorsport.com £164 plus je pistons both cost me £586 all in delivered
thanks
sean
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
20/20 vision
Sep 29, 2015 09:25 PM
mondeomark
Sep 28, 2015 06:28 AM
