new fault
Old Aug 23, 2007 | 11:04 PM
davie 3 door's Avatar
davie 3 door
Default new fault
Was out in the car last night when i decided to stop playing!!
Started to rough idle about 500 rpm then up to 1000 then cut out.
Starts fine runs perfect for approx 3 secs then cuts out!
1 checked 12v supply at pump
2 put in place good fuel pump
Still the same,
Anyone got any ideas please!!
Old Aug 24, 2007 | 01:04 AM
jawanne's Avatar
jawanne
check all air pipes and the ecu one..........also make sure that all your breather pipes are not lecking as rs turbo do.....hope that helps
Old Aug 24, 2007 | 06:17 AM
Do the wiggle test on the CPS connector.
Old Aug 25, 2007 | 07:34 PM
davie 3 door
Fault found to be a faulty MAP SENSOR!!
Old Aug 27, 2007 | 06:36 AM
I am surprised a MAP can cause a cut out, are you sure on this, justwant to know for myself as I'm nosey like this, thanks!!
Old Aug 27, 2007 | 05:02 PM
davie 3 door
Tryed ecu,cleaned all plugs,crank shaft sensor etc,changed fuel pump,fuel reulator,still the same.
Was about to give up for the day,un plugged the map sensor put old standard on back on and happy times all round it was running again!!
Going down to fit a new 3 bar map sensor tonight.
Old Aug 27, 2007 | 05:28 PM
I have similar problems with a BRAND NEW 3 bar sensor, thanks a lot for the info.
tankybaby66
Feb 6, 2016 02:24 PM
DixieTheKid
Sep 14, 2015 09:04 PM
NC53
Sep 13, 2015 03:05 PM
Si B
Sep 12, 2015 06:49 AM
