Should boost change when fitting a intercooler?
Old Aug 23, 2007 | 07:45 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Default Should boost change when fitting a intercooler?
Because iv just fitted a intercooler, and the car was boosting 16psi before and now only going to around 11ish?
Old Aug 23, 2007 | 08:27 PM
dave_y's Avatar
dave_y
yeah it will change, mine went from 15 to 20psi after fitting a big GRS cooler.
Old Aug 23, 2007 | 08:29 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Any ideas why mine has gone down?
Old Aug 23, 2007 | 08:37 PM
grsford's Avatar
grsford
are you sure that none of the boost hoses are kinked ,and that you didn`t catch the bleed valve when fitting the intercooler also is the intercooler new and what is it?
Old Aug 23, 2007 | 09:04 PM
bonus_boy's Avatar
bonus_boy
mate i fitted my grs intercooler yesterday and it went from 10psi to 5psi!!!
mine dropped aswell...does it feel sluggish and with the old intercooler it felt more responsive?
Old Aug 23, 2007 | 09:36 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
I think the problem is the boost hose at the top, with the bonnet up i revved it and it about squashes together!! Possible because iv fitted the intercooler and its trying to put more boost through now than normal, so iv orderd a set of silicone boost hoses, which arrive on saturday so hopefully this will sort the problem.
Its a airtech cooler, was going to get grs but the one i was bidding on got took off ebay, and could afford a new one cus iv just had to pay a £165 fine
Old Aug 23, 2007 | 09:37 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
The bleed valve is locked off with the locking nut so i doubt i could have done that, once iv tried the new boost hoses and if its still the same i will try adjusting the bleed valve but hopefully these boost hoses will work. Bonus Boy you using the standard boost hoses?
Old Aug 23, 2007 | 09:57 PM
grsford's Avatar
grsford
dont adjust the bleed valve mate if its been set up, spose it could also be a split boost pipe or poor seal some where on the intercooler
Old Aug 23, 2007 | 09:58 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Am i right in thinking its something to do with the boost hose just about totally squashing together when revving?
Old Aug 24, 2007 | 08:53 AM
bonus_boy's Avatar
bonus_boy
yes mate standard boost hoses...
havnt checked if my squash but i guess they do if there standard like yours was!!
have to order me some samco's or somthing!
sfs hoses good?
Old Aug 24, 2007 | 12:12 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
http://www.roosemotorsport.co.uk/
The only link you need for hoses.
Old Aug 24, 2007 | 06:33 PM
gee1599's Avatar
gee1599
i fitted a air tec intercooler with samcos no kinks etc and my boost droped from 18psi to 8ish i found the intercooler was restricting the air flow i now have a grs and it only droped 2psi which i sorted out via the bleed valve
p.s i have a airtec cooler up for sale but i would not bye it
Old Aug 24, 2007 | 06:50 PM
Rick's Avatar
Rick
Typical twin pass intercooler problem.
Old Aug 24, 2007 | 06:51 PM
LEE-RS's Avatar
LEE-RS
Custom
the boost drops due to intercooler core restriction it also dont help it being a twin pass intercooler you just need to turn the boost back up but not before getting it setup because it will be running leaner from the denser air from the cooler
but saying that if the pressure drop is to much (like the air tec intercooler) from core restriction you can begin to perform worse than before if the boost drop is high enough to negate any gains seen from temperature drops.
Old Aug 24, 2007 | 07:37 PM
bezo's Avatar
bezo
powered by K26
i never saw any probs like these when i fitted my grs fmic.
if any thing it felt more responsive.
Old Aug 24, 2007 | 08:31 PM
JamboRS's Avatar
JamboRS
focus rs 1672
really? you should see a pressure drop not a rise in boost pressure,whatever gave you the extra 5psi it wasnt the cooler
Old Aug 24, 2007 | 10:55 PM
bonus_boy's Avatar
bonus_boy
when i get my kenlowe fans i will refit my grs fmic.
but it was the same as people above went from 10psi to 5psi and not very responsive.
ive got the standard ecu...what bhp is max for them to cope with?
would i be able to refit the grs cooler and have it setup to run around 10psi with the standard ecu?
ive got a few mods done to it...and without the cooler (now) the ecu is fine...will it cope with the cooler?
Old Aug 25, 2007 | 08:26 AM
Fiecos Dan's Avatar
Fiecos Dan
You need to do a boost system pressure test, then check over and setup.
also matters on where your actuator is getting its boost feed from and where your measureing the boost.
Old Aug 25, 2007 | 11:56 AM
dave_y's Avatar
dave_y
well the only thing i changed was the cooler and silicone hoses which i guess would have helped but the first run on the rollers i could hear it detting/pinging away like crazy. operator said it was hitting 20psi when it was set up for 15.
Old Aug 25, 2007 | 12:34 PM
Fiecos Dan's Avatar
Fiecos Dan
but you could of had a boost leak above 5psi or so before you change your inter, and then solved it when you changed it.
Old Aug 25, 2007 | 01:30 PM
Andy_R's Avatar
Andy_R
I destroyed an engine after fitment of a GRS Evo3 intercooler, WOT in 5th showing a few psi extra.....hello Det....BOOM went the engine.
The increase in boost could only have been as a direct result of the more efficient IC, nothing else was touched.
Not knowing any better at the time I didnt think to have the car set up after fitment.
My advise to anyone fitting a new IC, exhaust or other parts that may atribute to change in preassure would be to have the car checked & set up if necessary.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
