Any one got a mk3-4 running n/a zetec?? help needed!!!
Hi, ive got a mk3 which was running 1.9cvh, 285 cam, 40`s, 4-branch etc... ive removed the engine to fit a 1.8 zetec 130 bhp, need sum help with sum points like, what fly-wheel and clutch? what alternator set-up? wiring loom? I`m on the hunt for a rst-3i fuel tank and pump, will these do?
i'm pretty sure the zetec bottom end bolts straight upto the b5 gearbox as used by the rst with limited slip
the zetecs in the mk5/mk6s used an i'mproved' b5 called the ib5 but obvio you won't get the limited slip and i'm pretty sure the mounts are slightly different.
Had a small problem wi the engine mount, ive modded the cvh bracket to fit the zetec block, but the rubber mount is fouling the oil pump, looked on a web site and they use a diff rubber mount part no.81AB6038AC, what car does this come on?
JoeyBoyden
Jan 4, 2024 02:36 PM
