Converting a T4 from internal to external wastegate
Old Jul 29, 2007 | 05:25 PM
Miller 3's Avatar
Miller 3
Default Converting a T4 from internal to external wastegate
How much would it cost as i have my eye on one and was just wondering what to do.
Doug
Old Jul 29, 2007 | 06:03 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
different exhaust housing is required. bin the actuator and get the manifold modded to accept an external one.
Dan
Old Jul 29, 2007 | 06:07 PM
Miller 3's Avatar
Miller 3
Already have the external wastegate and down pipe' was just wondering about the exhaust housing.
cheers
Old Jul 29, 2007 | 06:10 PM
SillyFezzaMk1
Rubber Rhino Crew
Well you can do it on the cheap to get you going by removing the vac pipe, tightening up the actuator arm and leaving it closed.....without the vac pipe it'll never function therefore working like it wasnt there....
However it'd look proper out of place next to an external wastegate IMO...something to think about if its the cash thats thats holding you back.
Dan
Old Jul 29, 2007 | 06:15 PM
Miller 3's Avatar
Miller 3
Dan
Thought about that before but i agree with you it wouldn't look right..
Any ideas on where to get the ex housing / cost
Old Jul 30, 2007 | 03:05 AM
RS500/364's Avatar
RS500/364
Ł300-Ł400
Old Jul 30, 2007 | 02:50 PM
Miller 3's Avatar
Miller 3
Originally Posted by RS500/364
Ł300-Ł400
Fkin hell
Old Jul 30, 2007 | 03:11 PM
SillyFezzaMk1
Rubber Rhino Crew
vac pipe off and save up then chap lol
Dan`
Old Jul 30, 2007 | 03:30 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The information supplied above is not strictly correct. The T4 is made up of three parts, the compressor housing, the turbine housing and the wastegate housing (see the picture below, so you can see what I mean ). So if you wanted to do it on the cheap, you could remove this and weld up the waste gate hole and then make an adapter plate to suit.
If you want to do it properly, then the external Garrett turbine housing without the mounting points for the internal one on the back to directly bolt on is Ł250 inc delivery.
However, if you want a direct replacement one and yours is in good condition, I would do you a direct swap for FREE plus carriage. This would be a like for like high flow 0.63 a/r external housing for your two piece one . And FYI it is available in smaller and larger a/r's .
Old Jul 30, 2007 | 03:38 PM
SillyFezzaMk1
Rubber Rhino Crew
I thought about suggesting you could weld up the hole but I htought it best not to as I might get shot down...I thought it could cause propblems it the weld distorted the housing, cracked at a later date etc....
Sounds like you have a good deal there mate...I'd get swapping if I were you!
Dan
Old Jul 30, 2007 | 05:23 PM
Miller 3's Avatar
Miller 3
Mike you have PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
mondeomark
Sep 28, 2015 06:28 AM
coscor86
Sep 20, 2015 01:21 PM
