where would long studs come out on the bottom of a yb
if you drilled all the way through where would they come out on the bottom of the block pics if you have them
bttt cos i would like to see these too
wheer else would you expect them to come out of if not the bottom of the block
they ain't gong to come out in australia ffs
or perhaps they'll end up in conan doyle territory in the lost world, or 20,000 leauges under the sea, or at the centre of the earth
only fucking with you, if you had a scrap block i'm sure someone would try it out but until the day that someone designs an engine where the head bolts also double up as the main caps, i don't think they will come out anywhere usefull
like was said earlier... what were you expecting... they will come out the botom of the block in the same pattern that is on the top...
why ask obvious questions if you werent expecting an obvious answer...
"twat"
why ask obvious questions if you werent expecting an obvious answer..."twat"
nilrem
think thats a bit harsh mate
he asked a simple question
and its true they will come out where they are lined up on the top, but they could of also come out inline with the main caps which is what im thinking he was looking into
as its not obvious aswell
Originally Posted by xr4x4rs
nilrem
sridgett
Oct 1, 2015 07:30 PM
SMILER258
Sep 28, 2015 09:04 AM
