running megasquirt on a cossie
hi guys, is anyone running there cossie on megasquirt? i know it does wonders and s#*t miracles for an rs turbo. but is it good for a cossie? my mate builds the kits and installs them just wondering if it was worth getting.
there is nothing wrong with the standard cossie management though..
even if you are runnning L1. you can upgrade to L8 or P8,
look what stu can do for L8 these days
EDIT: unless you are going for huge power and/or want all the toys etc that
other ecus give you.. but im guessing you aint?
people still run L1/6/8 p8 managment on big power engines!
ive used the megasqirt on a 21 turbo and on a zetec turbo THERE IS ABSOLUTLY NOTHING WRONG WITH THE SYSTEM
but it all depends on who will set it up as it has so much more to offer than the standard system out of te box .but if your not a mapper or no a good tuner then stick with a l8 and a few of the msd goodies
Originally Posted by Oranoco
I wouldn't trust MegaSquirt to run an RST engine let alone a Cossie one. It's sposed to be very crude indeed
by the way my ecu issues are sorted
well it was just a thought thats all i would like to see the 400bhp mark, its my brother mate who builds the kits and installs them and he says its a quality bit of kit, hes running 300bhp+ in his festa with megasquirt, i just wanted everyone else's opinion.
Thought not.
MS is far from crude and will hold its own with nnearly all ECUs in the under a grand market.
Thought not.
i mapped a focus rs engine last week with ms to 20psi with no problems
we raced it against my brothers jabasport maped octavia vrs and the focus well and truly spanked it
it took me 12 hours on the road to map it with all the egt guages electronic det cans wideband etc
the lads 4 pot brembos was shagged when he got his car back lol
all std stuff with secat and stainless exhaust/downpipe and on a flat out run it was knocking on 800 with 78 lamda
i could put on a fair bit of ignition whitch i wasnt expecting so it must be fairly low comp or have a rearly nice combustion chamber
Thought not.
Originally Posted by GARETH T
what was the EGT's on the FRS at 20psi? what turbo?
makes me laugh about the megasquirt people to ready to slate it on some bodies say so who probably never mapped a car
Gareth - suspect it's not in a Focus with std manifold
Dan - i can guide you through all/any aspects of MS, but you're best asking more specific questions. As a start, the V3 board, with the Megasquirt 2 CPU running MS2/Extra firmware, and twin coil drivers running wasted spark is a very very nice setup.
there are quite a few merkurs running on megasquirt now. they all say it is wonderful and easy to set up. you just have to fine tune the maps. you can also use the megatune software to let it automatically set up the base maps for you.
megasquirt rules if your on a budget and you have someone to ask question...my main issue with it is that due to its nature (DIY) you end up having to know a bit about it to get it to work...
Plus a lot of tuners wouldnt touch it when it first came on the scene a few yrs ago.....
Megasquirts main advantage IMO is that its software is open source, it probably has in excess of thousands of people all imputting int o its development and features, they offer baby boards..upgrades etc..all free of charge.
If you know what your doing a bit then you cant go far wrong with a MS setup.
Dan
Dan
Dan
Dan
had phil ringwoods v3.0 on my fiesta, direct coil fire, launch etc. was brilliant!! once i got to grips with it and theres so many forums on it and alot of helpfull pple if you have any problems
i use MS, i used to use omex M4, whilst being a very good setup the M4 was nowhere near as user-friendly as the MS, and i found it easyer to wire up and set up, i think i would go for the M4 IF i had a big buget, but for VFM you cant beat the MS in my opinion.
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
