Correct Boost?
Old Jul 7, 2007 | 02:35 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default Correct Boost?
What psi should i be running on my starge 1 saff on yellow injectors?
Old Jul 7, 2007 | 02:43 PM
cozmeister's Avatar
cozmeister
More boost Igor!
1 bar - or 14.5 psi
Old Jul 7, 2007 | 03:22 PM
RS LOZWORTH
o dear i think im running 17 need 2 turn that down then!
Old Jul 7, 2007 | 03:28 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
mine is running at 17 psi on yellows on my t34 and nothings melted yet but i tend not to take it above 5000rpm.
Old Jul 7, 2007 | 07:19 PM
Just go for a fuelling check as it depends on the chip/make.
MOST run around 1 bar as said though.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Russ Payne
Sep 25, 2015 08:29 PM
