water cooling on t3 turbo
Old Jun 13, 2007 | 05:26 PM
hog's Avatar
hog
Default water cooling on t3 turbo
hi
i sure it has already been covered , but i would like to know if any of you are running a t3 with out the watercooling pipes connected, and if its ok or not for the turbo , im allso thinking of fitting an oil cooler to keep temp in check , so am i right in thinking i would do away with the modine cooler if i fitted one ??
cheers for any advice
ant
Old Jun 14, 2007 | 12:36 AM
jon@work's Avatar
jon@work
T3 will be OK without water cooling.
Remove the modine if you fit an oil cooler - but you'll either have to join the original 2 water pipes together, or get some replacement pipework to replicate the original routing (but now from the heater matrix straight to the back of the head).
Old Jun 14, 2007 | 06:21 AM
Just make sure the air/oil cooler you replace modine wtih has thermostat in it.
Old Jun 14, 2007 | 06:33 AM
hog's Avatar
hog
cheers for that , i already have a cooler and take off plate from an old pinto , it has nt got a stat ,so do i need a new take off plate with one built in or just an inline one ?
thanks ant
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
robbo9006
11
Sep 1, 2015 02:10 PM
Aug 19, 2015 06:25 PM
