Tapping noise
Old May 24, 2007 | 09:04 PM
defendant's Avatar
defendant
Default Tapping noise
All,
I've got a slight problem with my cossie (4x4 RS Cosworth). I started it up the other day to take it for a spin, and let the engine warm up but after a couple of minutes the engine started making a slight tapping noise. I've checked the oil and that's right in the middle between minimum and maximum on the dipstick. I'm not sure about the oil pressure because i haven't had the gauge hooked up yet :-s I've never had this problem before and it started all of a sudden. Any suggestions???
Old May 25, 2007 | 06:06 AM
How many miles has it done ?, most likely the tappets, a good blast should soon sort it.
What oil are you using ?
A lot of the "el cheapo" tappets do this after a little while, don't know if yours have been replaced recently ?
Old May 25, 2007 | 06:19 AM
J9BBY's Avatar
J9BBY
Big end bearings?
Old May 25, 2007 | 06:42 AM
Top ur oil up 2 the max mark.
Old May 25, 2007 | 06:47 AM
Oil level will not affect it as it is enough to cover the pick up on low level.
BIG end bearings will be worse when first started, and they clank not tap.
Old May 25, 2007 | 07:52 AM
defendant's Avatar
defendant
It's done 83k (mileage), as for oil i haven't topped it up as of yet as i've only had the car for about 3-4weeks. The engine itself is a recent rebuild and i've been informed by the previous owner that it's only done about 1k. Before i took it out last week i checked the oil level and it was just over maximum and now it's in the middle of minimum and maximum. The last owner told me to use Mobile 1 oil. The tapping noise started all of a sudden after a few minutes warming up so i'm a bit baffled....
Old May 25, 2007 | 08:47 AM
Ridgey's Avatar
Ridgey
Mobil 1 15W50 NOT 0w40 as some people do
Old May 25, 2007 | 11:50 AM
defendant's Avatar
defendant
could it possibly be sticky tappets???? Although i'm a bit apprenhensive to start it up again until i know for sure in case it causes more damage :-s
Old May 25, 2007 | 03:50 PM
2wdsaph ben's Avatar
2wdsaph ben
ive got a tapping noise. mine has been rebuilt recently and ive also changed the tappets since then to ina tappets. i posted a thread on the rsoc ages ago and loads of people have unknown tapping noises from cosies. one person said his head was warped that why his was tapping
Old May 25, 2007 | 05:22 PM
Mobil 1 is crap for an engine with this mileage, use SILKOLENE PRO S from opie oils on here.
Just me personally but I would not even put Mobil 1 in my lawnmower.
If recently rebuilt may have used cheapo tappets, and not INA which are oe kit, and still only around the £80 mark.
I would firstly change the oil for above and watch the noise disappear, it will be perfectly safe to use until you get around to doing it as well, the hotter the better.
ps a warped head cannot cause the noise.
Old May 26, 2007 | 08:08 PM
col cos1's Avatar
col cos1
change the lifters ti ina`s,tappets are funny at times my car and my mates both tapped like hell when first built,mine are now fine 2k on,his are still there but not as bad
if it comes and goes it will defo be tappets,bottom end noise is alot deeper noise
i remember having to do a set on a 4x4 saph i had and it cured it instantly
tappets have a mind of their own
Old May 26, 2007 | 08:16 PM
robertthorpe's Avatar
robertthorpe
piston slap!!!!!! can happen afta a rebild or can just suddenly happen
Old May 27, 2007 | 07:03 AM
Piston does not suddenly happen or just after a rebuild.
It is caused by the rocking motion of the piston in the bore as it tries to rock under power stroke, was cured(pretty much) on 4x4 by offsettign change to wrist pin(gudgeon pin).
Old May 27, 2007 | 11:52 AM
havv's Avatar
havv
tappets most defitily had the same problem!, and think may have the same problem. just had a rebuild, but i think the tappets replaced were with cheap ones (£80), and i think i can hear the noise comingback.
gingeRS
17
Oct 2, 2015 09:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
marky_g
Sep 12, 2015 04:26 PM
rsturbo27
Sep 5, 2015 05:08 PM
