engine rebuild for evo6 useing evo 8 engine update 01 /06/07
Old May 22, 2007 | 09:45 PM
Uncle Winnett's Avatar
Uncle Winnett
Default engine rebuild for evo6 useing evo 8 engine update 01 /06/07
well id think its time to show you what ive been up to after my engine when pop on a rolling road day 1st run did 432bhp and 389ilft then on 2nd run it let go big time
got the engine out tock quite a bit as the big turbo made it quite bad to take it out in 1 go with the gear box and transfer box on as well note to self leave turbo off when i but the egine back in any way there are 2 hols in the block 1 in the front and 1 in the back any way looks like the rod has give up the ghost heres the pics
well got on with the stip down didnt get as much done as id off like because the gear box dosent want to come off
any way here the pics
head looks ok thank god so if i can get the rest off the block striped along with the evo 5 engine and the evo 8 engine
right guy bit off an update. stripd the damaged egine off every thing now found a bit more dameg to the oil pump and 1 off the balce shafts and oil squarts any body need any paper weights. here some pics off the damage
balnce shaft
oil pump
damage to the crank
damage to the block bore
damge to the oil squater
so then i moved on to the 8 block that is being used for the rebuild this was easy to strip as it just had the crank and balnce shafts and oil pump on so only tock about 30 mins nothing much to see there
just droped this off at the machine shop to be checked over to make sure there is nothing wrong with it
then i crack on with the strip down off the 5 block as i need the oil pick up pipe and the oil baffel plate out off it
how i got it
head off i was told it had det so this is what i found will need a rebore
2 ****ed pistons
close up off the bores
and that was that for yeaterday
picked up my breaks discs from the machine shop all nice and new
jobs that im doing today are front anti roll bar bushes front wishbone bushs
and also mounting the apexi oil pressure gauge in the drivers side air vent oh and if i get time new break pads on the rear still need to find some old engine and gear box mounts to use for my nice new powerflex kit
got my breakes back from machine shope to day all nice and new now
also fitted front antiroll bar bushes bit off a job that wouldent like to do that with the engine in
also i fitted new bushes in front wishbone good job i had access to a press as i saw over 8 ton off pressr on 1 off the bushes
also block is ok so they are geting on with all the work on that that will be ready on tuesday
also been on to the suppler off the stoker kit got a good deal on the kit and head gasket and stuff so that should be here early next week to
new bits turnd up
crank
rods
head gasket
sheels
oil pumb
more gasket
imiming belt and rollers
and new ajuster
started puting it all back togethere to day clend most off the engine bits up but did not do much to the bock as im still waiting for a few bits butwill just do what i can over the next few days
block all cleand up
oil squarters in
sheels in
sheels in the carry
crank in
all bolted up loss as i forgot to get arp studs so just used the old bolts for now untill the arp get here
thats it for today
john
update time
arp crank bolts going in
pistons and rods going in angain with arp bolts
arp head bolts going in
john
have you check clearance of rod on bottom of bore as it gets pretty close on stroker crank
yes i have and all seems good
any way todays up date
cheap way to get a balance shaft stuby
take 1 bent balance shaft
cut it down
you will notece it has a hole in it tap it and in sert a bolt with lock tight
cut the bolt down and file it flat
one stuby oil shaft
oil pump on
oil baffel plat on and pick up pipe
oil filte houseing on
sump on
knock sensoir on
oil presure sensoir on
water pump on
hks 1.2mm head gasket on for test fit
thanks john
Old May 22, 2007 | 10:19 PM
Daviet's Avatar
Daviet
that didnt half let go
you need to update to sig tho
slammedorion's Avatar
slammedorion
Looked as mess... nice to see it going back together... bet you can't wait... Do like the Evo's maybe one day...?
I had engine problems with my STi type R... That resulted in a rebuild ( Big power now, big ŁŁŁŁ too )
Old May 23, 2007 | 01:02 AM
Tomassi's Avatar
Tomassi
cant believe the damage to the block
Old May 23, 2007 | 07:15 PM
Uncle Winnett
did a bit more today forgot to take pics as i was going but hears 2 pic of how it is now
john
Old May 24, 2007 | 07:11 AM
M K's Avatar
M K
THAT WAS A PROPER ENGINE FAILURE
nice to see it being built back up
Old May 24, 2007 | 08:43 PM
Dan's Avatar
Dan
FOOK! That was MASSIVE damage!
Saw your car blow up on a video on youtube or somewhere!
Old Jun 1, 2007 | 09:29 PM
Uncle Winnett
Old Jun 1, 2007 | 10:06 PM
CosKev3's Avatar
CosKev3
Good pics m8
What was the bang like when the engine gave up??????
Never heard an engine go like that
Whats the score with using the Evo 8 block?????Stronger etc
And one last thing,the colour of the verniers suite the Evo down to the ground!!!!!
Old Jun 2, 2007 | 08:36 AM
AlexD's Avatar
AlexD
Post Miester !
Holy Shite !, Now thats blown !
Old Jun 2, 2007 | 07:03 PM
Uncle Winnett
Originally Posted by CosKev3
Good pics m8
didnt make a big bang really
stonger block
the hks only come in that colour
john
Old Jun 3, 2007 | 01:07 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
dont you wish engine internals would stay . . . . . well . . . internal!! what power you hopeing for now?
Old Jun 3, 2007 | 09:25 AM
- Sim -'s Avatar
- Sim -
good rebuild action.
Like your car and the new parts really. Good EXPENSIVE HKS Stuff.
Wish you the best for the new engine, and looking forward to any updates !!
Old Jun 3, 2007 | 07:17 PM
Uncle Winnett
450 bhp and about the 450lbft
will do for now
john
Old Jun 7, 2007 | 10:23 PM
Uncle Winnett
it runs
john
Old Jun 9, 2007 | 05:12 PM
ADT168's Avatar
ADT168
nice, bet thats a quick car
Old Jun 9, 2007 | 05:30 PM
rapidcossie's Avatar
rapidcossie
amazing work mate
JoeyBoyden
Jan 4, 2024 02:36 PM
EoinXR3
Sep 7, 2015 05:44 AM
Aug 20, 2015 09:21 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
