removing windscreen rubber from saph cosworth
Old May 22, 2007 | 06:06 AM
mondeomark's Avatar
mondeomark
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
Default removing windscreen rubber from saph cosworth
hi i am painting my saph cossie and i want to remove the windscreen rubber can i do this or do i have to take the complete screen out???
Old May 22, 2007 | 06:35 AM
Screen out, if it has any cracks it will go big time so be warned, expense on the way!!
Old May 23, 2007 | 12:02 AM
CosKev3's Avatar
CosKev3
I'm sure the rubber will come out
The screen is bonded in on a saph,so the rubber is only a trim to hide/tidy the gap between screen/body
Old May 27, 2007 | 02:12 PM
whoopty's Avatar
whoopty
Yes it will come out just get hold of it and pull it out, iv just done mine
they dont go back in that easy you may nead to glue it back in with a fine beed of windsreen glue.
Old May 27, 2007 | 02:39 PM
neil andeRSon's Avatar
neil andeRSon
it'll come out as long as it aint been replaced before. there's a chance the moulding may be stuck in the glue..
Old May 27, 2007 | 06:18 PM
dakar's Avatar
dakar
Defo will come out as the screen is bonded just had autoglass put a new screen in mine and they have cut a big chunk out of my dash in the process
Old May 27, 2007 | 09:20 PM
costina's Avatar
costina
Live long and prosper!!
TWATS hope u get some comp
Old May 28, 2007 | 08:27 AM
dakar's Avatar
dakar
To be fair they have been very good and are paying for a new dash to be fitted
original
Apr 28, 2026 05:20 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
borboyous
Aug 22, 2015 11:17 AM
Aug 14, 2015 07:29 AM
