Valve Springs
Old May 20, 2007 | 07:03 PM
Cosworth Bassie's Avatar
Cosworth Bassie
Default Valve Springs
When is it really neccessary to upgrade the std Cosworth valve springs?
About which cam lift and engine rpm?
I'm going to run a bd 14 inlet and about 7500 Rpm, do i need other uprated (double) valve springs?
Regards,
Bas
Old May 21, 2007 | 02:28 PM
sygjim's Avatar
sygjim
Old May 21, 2007 | 02:57 PM
Cosworth Bassie
What do you mean?
Old May 21, 2007 | 02:59 PM
sygjim's Avatar
sygjim
i have the same question than you
Old May 21, 2007 | 04:49 PM
Mr 19"'s Avatar
Mr 19"
How much power are you aiming for? If you are running high boost pressure, the valves will not close on higher revs with just standard springs. I use an inner spring from Audi. Works perfect and they are cheap too. Just drop in, no mods.
Old May 21, 2007 | 06:50 PM
Cosworth Bassie
I'm aiming for 480-500 bhp.
I see a lot of people over here who are giving their specs, and i don't always see the valve springs.
And the BD14 doesn't have that much lift so i was wondering if it's really nesseccary????
Regards,
Bas
Old May 22, 2007 | 05:00 AM
Cosworth Bassie
Nobody?
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
RS-Rikki
Sep 21, 2015 07:27 AM
