Cossie front crankshaft seal/crankshaft dimensions
Old May 17, 2007 | 10:26 PM
Azrael's Avatar
Azrael
Default Cossie front crankshaft seal/crankshaft dimensions
I am just rebuilding my engine, but the crankshaft has been machined before for smaller dimeter fron crankshaft seal. I want it welded and machined back to nominal dimetion. Can someone plase post me inner diameter of front crankshaft seal or even better diameter of the crank in this place?
thanks a lot
Old May 18, 2007 | 09:30 AM
Azrael's Avatar
Azrael
Up
Old May 18, 2007 | 02:30 PM
jon@work's Avatar
jon@work
it's the same as the auxilliary shaft seal - could you measure that ?
Old May 18, 2007 | 08:57 PM
Azrael's Avatar
Azrael
Which auxilliary shaft? Gearbox?
Old May 18, 2007 | 09:47 PM
jon@work's Avatar
jon@work
oil pump/dizzy driving auxilliary shaft on engine
Old May 18, 2007 | 10:30 PM
Azrael's Avatar
Azrael
It's small turbo... I don't think it has it.
Old May 18, 2007 | 11:48 PM
jon@work's Avatar
jon@work
it doesn't have a dizzy, but it's got the sensor there, and this also drives the oil pump
Old May 19, 2007 | 05:45 AM
Azrael's Avatar
Azrael
I'll have a look then if you say they are the same.
Old May 19, 2007 | 11:33 AM
jon@work's Avatar
jon@work
the oil seals are the same
Old May 19, 2007 | 05:53 PM
42-56-7 is the front crank seal, so 42 is the one you want.
Do NOT use ford ones, use VITON ones as these will not leak!!
Old May 19, 2007 | 06:55 PM
Azrael's Avatar
Azrael
tabetha thanks a lot!
My car had machined shaft in this place and Honda NSX seal!!!
Old May 20, 2007 | 06:49 AM
A seal is a seal, just measure your crank and adjust number accordingly, ie if it has been ground down top 40 mm then get a 40-56-7, readily available at all good seal places!!
original
Apr 28, 2026 05:20 PM
Oct 9, 2015 07:38 PM
Aug 29, 2015 08:16 PM
cossie330
Aug 22, 2015 12:00 PM
C2 MAK
Aug 20, 2015 09:46 PM
