original t3 4x4 turbo max boost
Old May 17, 2007 | 08:44 PM
Souleyman's Avatar
Souleyman
Default original t3 4x4 turbo max boost
Hi there! What the maximum boost can hold up the stock 4x4 T3 Saph turbo without any problems and so on?
Old May 17, 2007 | 08:49 PM
rapidcossie's Avatar
rapidcossie
15 psi
Old May 17, 2007 | 09:01 PM
Souleyman's Avatar
Souleyman
rapidcossie
It means that the promiced 1.5Bar (21-22psi) with greens, chip and -31 is not correct?
Old May 17, 2007 | 10:12 PM
daz1968's Avatar
daz1968
It can be set up to 22psi, my original 2wd T3 was, just that with the standard bearing life would be reduced, but by how much is subjective, as it depends how the car is driven, I just opted for a 360deg bearing to be fitted before I get it checked over after the engine build,
Old May 17, 2007 | 10:19 PM
mechanic28's Avatar
mechanic28
did not think a T3 could push out 22 psi and hold it?
Old May 17, 2007 | 10:51 PM
col cos1's Avatar
col cos1
mine held 18 with no probs
Old May 17, 2007 | 11:27 PM
simonc's Avatar
simonc
I blew 2 T3 turbo's @ 1.5 bar in a matter of weeks on my Cossie, in the end it worked out cheaper to get a T34 in the long run.
Simon.
Old May 18, 2007 | 10:10 AM
Souleyman's Avatar
Souleyman
Ok, if I want to uprate my street car to 330hp on greens and so on, I must better to use T34 instead my T3?
Old May 19, 2007 | 05:34 PM
T34 way better, just get 360 and step gap seal at same time.
The turbocentre 01924 404112, ask for ANDY or CRAIG.
Old May 19, 2007 | 06:20 PM
Souleyman's Avatar
Souleyman
Kindly thank you for the answer. Please, describe me what is the "gap seal"? It's the part from rebuild kit when installing 360 bearings?
Unfortunately is not so easy to call the Turbocenter from Russia.
I try to talk with our turbo-rebuilders, but all of them prefer the modern GT ball bearings turbos and don't like to work with old T-series.
But for installing the GT2871R or GT3071RWG needed too much modifications...
Or I'll try to write to Andy and Craig to sail me the ready to use cartrige or another needed parts...
Old May 19, 2007 | 06:27 PM
melzieann's Avatar
melzieann
Simon.
i did exactly the same
1st turbo held 22psi and went bang
2nd turbo held 18psi and went bang
so i got a T35 instead
Old May 22, 2007 | 11:59 AM
Twellsie's Avatar
Twellsie
mine runs at 1.7 bar with no probs
Old May 22, 2007 | 05:59 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine held 21 psi before i fitted my t34
Old May 22, 2007 | 06:07 PM
Souleyman's Avatar
Souleyman
Does anybody knows the parameters of T34? (A/R, trim, wheels of cold and hot parts)? Can't find this nowhere...
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
