Saff rear bumper removal?
Old May 16, 2007 | 02:35 PM
cosrep's Avatar
cosrep
Default Saff rear bumper removal?
As above how do I get one off, I have the clips off on the sides but is there more fixings at the back?
Old May 16, 2007 | 03:13 PM
jon@work's Avatar
jon@work
2 bolts in the boot
Old May 16, 2007 | 03:16 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Two SIEZED Torx bolts in the boot
Mine are either siezed or torqued up to the nuts. T30 is the right size, but they've probably welded themselves to the body/chassis rails - mine have.
Old May 16, 2007 | 03:20 PM
R5COS's Avatar
R5COS
yep as above 2 torx in boot maybe 4 if a previous owner put 2 more in to hold the bumper up more combat sagging etc spray some wd 40 on bolts the nite before as if it hasnt been off in awhile it could be tricky..
Old May 16, 2007 | 03:23 PM
R5COS's Avatar
R5COS
hi cosrep theirs an rs show in letterkenny dis weekend are you an irish owners club member if not wanna sign up ??? pm me and ill send details....
Old May 16, 2007 | 05:02 PM
cosrep's Avatar
cosrep
Thanks for the reminder, If I can get off work I'll be there, I'm already a member of the IRSOC, but thanks for asking. Hope to see you there.
Old May 16, 2007 | 05:05 PM
saff cosworth's Avatar
saff cosworth
i thought it was the 27/05/07
i could be wrong
Oct 9, 2015 07:38 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
