Greens!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
Old May 13, 2007 | 04:05 PM
cameron2's Avatar
cameron2
Default Greens!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
Does anybody know the tech spec on light green injectors?
What will they run etc?
Old May 13, 2007 | 04:07 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
More than standard Yellows and Blues but less than Dark Greens
Steve.
Old May 13, 2007 | 04:11 PM
big_wig_074's Avatar
big_wig_074
as in the porsche ones that end in 355?
apparently theyre ok for about 17psi and 300 odd bhp on a 2wd cossie?its usually easier to sort a 803 (dark green) setup,plus it sets you in stead for more later on with the 3 bar etc..!
Old May 13, 2007 | 04:16 PM
Billabong's Avatar
Billabong
Light green - 0 280 150 355 - flow approx 300cc/min (not significantly more than std injectors).
Dark green - 0 280 150 803 - flow approx 383 cc/min (fitted to Porsche 944 turbo as std)
Old May 13, 2007 | 04:19 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
bill..............what are 400's??????
Old May 13, 2007 | 04:40 PM
Billabong's Avatar
Billabong
approx 437cc/min
Should add that figures are at 3bar fuel pressure, from the data I have - except the 803's which were at slightly less than 3 bar. Figures only for general comparison, as obviously your tuners will supply a chip spec'd to suit from the benefit of their experience.
timsrs
Nov 13, 2018 11:48 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
Bransby
Sep 11, 2015 01:09 AM
Neil Clark
Sep 8, 2015 07:06 PM
