ANYONE USED A NORMAL SUMP GASKET ON A 4X4 COS?
Old May 13, 2007 | 01:55 PM
IANS2RST's Avatar
IANS2RST
Default ANYONE USED A NORMAL SUMP GASKET ON A 4X4 COS?
as above really, has anyone used a sump gasket from a pinto sierra or the 2wd sapphire rather than the recommended silicone sealer?
would be a lot neater if there was one available
any particular reson ford used silicone?
Old May 13, 2007 | 02:08 PM
Butch.'s Avatar
Butch.
if you put a sump gasket on it you will have to fabricate the crank sensor housing as it will not be close enough and wont start
IainRS1700T
Sep 25, 2015 06:44 AM
little bram
Sep 21, 2015 02:50 PM
tib2220
Sep 14, 2015 12:33 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
