Lap times around Coombe (just got Back) PICS INSIDE
Up there testing on Thursday just would like to know what times that you guys do around Coombe
Please could you list below and specs your running
IIRC (which I probably don't) I did 1:22s-1:24s in my Saph at 370 bhp.
Also, I think my brother does 1:27s ish in his 205 Mi16
When I timed Porkie and Martin H round there, I never saw faster than 1:20s, although another friend told me he saw 1:18 on one of their laps.
Seen a lot of normal ish 205s / Xr2 / RS2000 type cars all in low 1:30s
What are you going to be testing? Meastro?
Si
Si
The maestro next thursday, got a testing day, not cheap but 3 cars on circuit at any one time, 15 min runs, so also get some practice in
Originally Posted by Tony Ryan
1.14's the only time i ever went there last year . Good circuit , should see 12's this year .
do you know what date(s) you will be there this year? The Reyland cars "should" be well under 1:20, closer to tony's 1:14, although going out and enjoying yourself on a track day and posting lightning times don't necessarily coincide
We run a Rover 25 MGZR in the Castle Combe saloon championship - 1800 normally aspirated K-series (around 220bhp) and treaded road tyres, in a grid of 30-odd this car runs low 1:19 during a race.
May 28th ,
july 14/15th ,
the may round is the day after i do snetterton with the BARC tho so might be pushing it a bit . I watched your race when i was there last year, the rovers seem to have that sewn up , a couple of storming tomcats seemed to be the class of the field with the ZR's .
july 14/15th ,
Last Castle Combe Action Day the Reyland cars were lapping at 1:18 - 1:19 with a clear(ish) track.
For reference, Cossie's with a road set up suspension and 330 - 350 BHP will usually manage 1:24 - 1:26 on a tidy lap.......Anything under 1:24 in a road car is a VERY good time.
Well we shall see, the car is around the 220bhp mark and weighs a smidge under 800kg.
It has full cage which go through to turrets, adjustable camber and Leda suspension all round so should handle quite well, we have also relocated battery and tanks to centre of car low down.
Brakes are 4 pots with 300mm disks so should be ok for weight of car.
Dare say we will be adjusting stuff throughout day
Main thing is to enjoy and stay safe and learn a bit more, hopefully will hold its own on Bristol and Swindon day at Coombe
C ouple of years ago when Martin was out in the old Reyland Escos at Jap crap day, when the tyre came off and fucked the wing, and he hack sawed it off.. and it was wet/dry/wet I timed him at 1.19 ish.
Jake
Jake
Well were back from Coombe
We had a couple issues on first real shake down, O-Ring on the oil cap
, we started suffering a couple brake issues last couple of laps, we since found the brake disks now has 3 big cracks going through them, so new set of disks required
From the start we were struggling with the tyres, these were fitted to the wheels when we got them, so a new set of Toyo 888s are needed, wihich would make a massive difference.
We also need to adjust the camber on the front but thats a simple job
Lap Times wise once a handfull of laps were completed we was seeing 1:25s but we think better tyres, camber sorting out and more experience around coombe they will drop.
Hitting 1.5 Bar boost
, we started suffering a couple brake issues last couple of laps, we since found the brake disks now has 3 big cracks going through them, so new set of disks requiredFrom the start we were struggling with the tyres, these were fitted to the wheels when we got them, so a new set of Toyo 888s are needed, wihich would make a massive difference.
Part worn tyres for sale only 5 years old
Get that bloody focus out of my way
Loon coming through
A little vid
Loon coming through
A little vid
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!
Thats ok then
I've been on a normal trackday with those things out and nearly killed someone as they stalled in the middle of a corner and couldnt restart it
Thats ok then
Hi everybody, it was along time ago, '96 ish, there must have been a track change because I did a 1.05 something, which gave me a 100mph average lap in the 500, I remember 7600 in fifth through Westway.
Andy
Andy
Andy
Andy
"bobbies" and the "esses" have been added since then
great shame in some respects, but was VERY fast before..
Hi RichM, they have to take as much risk away as possible due to the nanny state, so they have to slow the racing down, the cheapest way to do that is chicane's, great shame that circuit's are happier to have slower less exciting race's to save money !
Andy
Andy
Good work Jase
Especially on Yoko A520s
I have them on my road wheels, and I'd rather run my 888s year round, than run on my road wheels!
888s will cut at least a few seconds of that time in the dry I'm sure, they do make that much difference. Have you been round with an instructor? As I'm sure with taking the right line, even more time can be saved.
Right lines were something I never bothered with though
When you up there next? Will Ford or Pug wheels fit your car? As you're welcome to try my 888s on your car.
Si
Si
Andy
Andy
Originally Posted by SiB
Good work Jase
Si
Si
Good work Jase
Si
Si
If any of my track cars were working properly I'd be up there with you!
Si
Si
We will be knocking on your door in a couple of weeks to supply us with rubber, problem is the sizes at present there are 2 different sizes on the car so we need to comprimise on size and see what we an get away with
Originally Posted by Jasesapphy
Si
Originally Posted by GVK.
This is a 1:18.5 from my mate Graham's old mk1 Golf, it had a normally aspirated 20v motor on ITBs..
http://www.youtube.com/watch?v=e7fY_H5Bpxo
