question about mondeo clutch
Old May 12, 2007 | 07:50 AM
lammylama's Avatar
lammylama
Default question about mondeo clutch
ive just brought an 04 plate mondeo 130tdci from a dealer which on the day i brought it had a clutch,flywheel and slave cylinder fitted before i picked it up. I test drove the car and all was fine,i put it on my trailer and drove the 125 miles home to find that when i got there the clutch was no longer working. When i pumped it a few times it comes back to life a bit but its not as i should be. Obviously its a hydraulic clutch but does anyone know what the prob could be???...does it need to be bled and how do you do this. I personally reckon its the slave cylinder but are these inside the gearbox on the mondy.
Good thing is that i called the dealer and hes willing to pay for whatever it needs which is good but if its a quick fix ie bleeding system then i may do it myself.
Old May 12, 2007 | 08:12 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Sounds like it hasn't been bled up properly thats all
Old May 12, 2007 | 08:44 AM
filthyrichie's Avatar
filthyrichie
they can be a swine to bleed ,is the pedal very loose in feel , if so try gently bleeding it leaving a few mins in between then sit and pump it , ususally works well for us , even tho there is no air u sometimes dont get a pedal sraight away
Old May 12, 2007 | 08:48 AM
lammylama's Avatar
lammylama
nice one mate.....how do i bleed it and where is the nipple??
Old May 12, 2007 | 09:30 AM
James's Avatar
James
on the top of the slave sticking out the gearbox, if you look to the left of the battery down at the gearbos you should be able to see it. it's 11mm i think and plastic nipple & thread in most cases so don't over tighten it whatever you do!
Old May 12, 2007 | 11:36 AM
lammylama's Avatar
lammylama
cheers james...will have a look later
Old May 12, 2007 | 03:36 PM
dave green's Avatar
dave green
On some of the mondeos you have no nipple you have to bleed them by removing the pipe
Dave
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 20, 2015 11:47 AM
richierich1986
Sep 18, 2015 03:29 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Chopshop85
Sep 12, 2015 06:42 PM
