is worth polybushing the top struts?
May 11, 2007 | 12:42 PM
500bhp Cosworth in making
fitting my new konis his weekend all my car is polybushed apart from the top struts that sits ontop of the damper cups? is this worst getting done or not?
May 11, 2007 | 12:43 PM
worth
may aswel if the rest of the car is done
Yep worth getting done, or use 909 top mount bushes, I prefer them myself.
May 11, 2007 | 12:51 PM
May 11, 2007 | 12:55 PM
May 11, 2007 | 01:02 PM
May 11, 2007 | 03:22 PM
Got powerflex poly on mine so changing to 909 tops.
May 11, 2007 | 04:15 PM
i don't like it, it is too harsh on a road car - u need some give imo.
May 11, 2007 | 04:16 PM
Quote:
Originally Posted by G.B Turbo Solutions
worth
as well
Never thought about doing it on my car, guess I have to rethink that.
May 11, 2007 | 05:05 PM
tabs, can u get the 909 ones still?
as i need some.
May 11, 2007 | 05:11 PM
ok now to rear strut braces do they go across the struts in the boot? and is it best to get rose jointed?
May 11, 2007 | 05:14 PM
Quote:
Got one on mine too .
May 11, 2007 | 05:15 PM
hot any pics is it in the boot?
May 11, 2007 | 05:16 PM
Just use Escort Cosworth bushes, they look the same but a MUCH stiffer.
No pics m8 but yeah in the boot,got mine from rapid ford.
May 11, 2007 | 05:18 PM
Quote:
too late just order some
i like the look of this strut brace on the rear
http://cgi.ebay.co.uk/GGR483-Escort-...QQcmdZViewItem
May 11, 2007 | 05:21 PM
Quote:
Originally Posted by Andreas
worth
as well
Mine is done all around the car.
May 11, 2007 | 05:40 PM
martin, are they? still available from fords i hope?
will use them instead of the 909 ones then if i cant get them.
obviously any new bush is going to be better than a 20yr old one
May 11, 2007 | 05:42 PM
Ex Full Price gold member
Quote:
Bit pedo mate isn't it
May 11, 2007 | 05:44 PM
May 11, 2007 | 05:45 PM
May 11, 2007 | 05:47 PM
May 11, 2007 | 09:30 PM
i always leave these out when buying the front end kit,too harsh for the roads up here
May 12, 2007 | 12:53 AM
Last set I bought 909 were about 4 years ago!!
Roosie, just buy a bar of metal and drill a hole in each end then two longer bolts to go through the top mount holes job done for a few quid!
JK12
33
Apr 26, 2021 12:09 PM
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
RIB1122
Aug 12, 2015 08:49 PM
