Gearknob/gearstick rattle
Old May 9, 2007 | 06:27 AM
jaiscossie's Avatar
jaiscossie
Default Gearknob/gearstick rattle
Any ideas what this could be? thought it was the old gearknob so brought a brand new genuine cosworth one but is still doing it. Really annoying to,altho it stops when you put pressure on the gearknob
Old May 9, 2007 | 08:01 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
is it a 2 wd ?
has the sitck been cut down? if so then the rubber bush may of been removed that would cause it to rattle
Old May 9, 2007 | 08:17 AM
2001ode's Avatar
2001ode
If it is 2wd, gear knob rattle is often from turbo damper trouble.
Check it, and renew.
Regards
Claude
Old May 9, 2007 | 07:46 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Are you sure its not just the insert ratttling? I've had this before. Try just touching the insert and see if it stops. Odds on it does. If so glue the bleeder in as they work loose.
Fudgey
Sep 17, 2015 01:06 PM
Bailes1992
Sep 3, 2015 02:17 PM
Roosie
Aug 13, 2015 07:40 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
oriont
Mar 2, 2005 06:32 PM
