please can some 1 tell me ?
Old May 7, 2007 | 07:03 PM
garyrs's Avatar
garyrs
Default please can some 1 tell me ?
hi to all , ok well here goes in jan-feb i was haveing trouble with leaking water ,so i took to bits and done the core plugs on the head exhaust side
then put back together an the was no leak from under car , but still loseing water, after a compresion test wich was all good, the was water in 3+4, so i took the head off , head gasket was broken in a few places but when i had a good look thismorning ,it has a wire rung block, however the was no wires in it????? can anny 1 give me anny info on this system were can i get some wires from? is it a standard size that is the same to all blocks or does it depend who done it? cheers gary
Old May 7, 2007 | 09:48 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
all you need is mig welding wire hth
hth
Matt
Old May 7, 2007 | 10:27 PM
garyrs's Avatar
garyrs
cheers matt,
Old May 8, 2007 | 06:27 AM
Depends on the depth of the groove, and when done as favourite used to be PIANO WIRE, but superceeded by more modern materials now and better sealing techniques materials.
