Not Boosting Properly and Stuttering?
Old May 3, 2007 | 08:15 AM
J9BBY's Avatar
J9BBY
Default Not Boosting Properly and Stuttering?
I have switchable high / low boost on my car. Works fine on low boost (8psi), but when switched to high boost it boosts to only 14psi (stage 3) and coughs and splutters. Changed to a bleed valve and boosted up no problem, so thought it must be the amal valve. Got a new one and has made no difference.
Any suggestions????? HELP PLEASE!
Cheers,
Pete.
Old May 3, 2007 | 08:21 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I'd check the actuator, could be a little weak and unable to hold the extra boost pressure.
Also, check your boost hoses (air intake, turbo to i/c and i/c to throttle body), see if they are squishy. When the turbo draws air in, if the hose isn't strong enough it can collapse, leading to an insufficient air supply.
Fuelling (pump, pump electrical supply, filter, injectors) and plugs would be the next thing I'd check. As boost goes up, you need more fuel and a strong spark
Hope this helps.
Old May 3, 2007 | 05:57 PM
Just put a group a coil on it.
£32 delivered, MATT LEWIS 01922 692424.
Use a 0.6mm plug gap also, with decent leads like MAGNECOR.
check your phase and cps gap at same time, though they will not be the cause
Old May 4, 2007 | 12:37 PM
J9BBY's Avatar
J9BBY
Cheers for that. HAve ordered up some new plugs and a group a coil and i'll take it from there.
Everything else has been checked or replaced - petrol and ignition side.
A trip to a rolling road might be in order if that doesn't cure the problem.
Thanks again.
Pete.
Old May 11, 2007 | 09:30 AM
J9BBY's Avatar
J9BBY
Changed coil and plugs and no difference, so put bleed valve on, bypassing the amal valve altogether. Now boosts up fine with no stutters etc.
What could this be? A fault in the ECU?
Amal valve has also just been changed.
Any suggestions gratefully received!
Pete.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
dojj
Sep 29, 2015 10:32 PM
Russ Payne
Sep 25, 2015 08:29 PM
