fuel filter on sapph
Old Apr 29, 2007 | 04:58 PM
cossiegreg1's Avatar
cossiegreg1
Default fuel filter on sapph
can i please have an idiots guide on changing a fuel filter.I never done it before so any tips much apreciated. its 2wd. thanks Greg
Old Apr 29, 2007 | 08:12 PM
rabmc's Avatar
rabmc
Hmm really is basically undo the bolt type connections on each end of filter and replace, there will obviously be a bit of fuel there so get something to catch it in , its very easy
Old Apr 30, 2007 | 05:49 AM
As above, they hold quite a bit of fuel, there is also one bolt holdin the filter to bracket which often breaks, the captive nut, so will most likely have to effect a repair here ?, but very easy to do.
MIne surged like buggery after filter, just let it run for 5 minutes it was up/down/up/down, mostly up to around 2500rpm, but settled down after this.
The difference on the road was amazing though, far more bottom end than before!!, so well worth doing.
The filter is "HANDED" so only goes in one way with an arrow so you can't get it wrong as bolts are a different size and will not fit each other, don't lose the copper washers and make sure the sealing faces are nice and clean.
ps and don't get petrol in your face it stings a lot(appartently!!)
Old Apr 30, 2007 | 09:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
don't try and re-use the copper washers, they will leak - always get new
Old Apr 30, 2007 | 02:02 PM
My ones did not leak, and have never had any that did, although I do check, if they did I would heat them up to cherry red and drop them in oil to reanneal them as it's cheaper.
Old Apr 30, 2007 | 07:08 PM
cossiegreg1
cheers guys, where will i be able to get some copper washers?
Old May 1, 2007 | 12:40 AM
jon@work's Avatar
jon@work
easiest place would be Ford
if not, then any hydraulics supplier (eg Pirtek)
Old May 1, 2007 | 07:38 AM
foreigneRS's Avatar
foreigneRS
Testing the future
even halfords do them
most garages will have a service kit full of them and will usually give you some for a drink
Old May 1, 2007 | 08:24 AM
autonero's Avatar
autonero
I got them with the new filter . Didnt u?
Old Jul 10, 2010 | 10:20 AM
AndyPen's Avatar
AndyPen
Every one I have done has leaked when using the old washers - Tab's trick of heating them helped a lot but we still had a very tiny leak. Now done it 4 times with new washers and it worked every time bar one... that was because the actual union had been damaged by not sitting well on a re-used washer... there was a very light score and that was enough to make it leak.
Old Jul 10, 2010 | 10:29 AM
Originally Posted by archebald23
you can buy the fuel filter set, all you need is included and it too have a replacement manual. just follow it step by step and you'll be fine.
He may have done it by now, over 3 years ago!!
Old Jul 10, 2010 | 02:48 PM
AndyPen's Avatar
AndyPen
Ha ha - well spotted mate.. doh!!!
timsrs
Nov 13, 2018 11:48 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
