dataloggers for individual cylinder egt monitoring
Old Apr 28, 2007 | 03:01 PM
leecavturbo's Avatar
leecavturbo
Default dataloggers for individual cylinder egt monitoring
anyone recomend 1?
Old Apr 28, 2007 | 03:06 PM
Rick's Avatar
Rick
innovate TC1 linked to LM-1 and /or laptop.
Old Apr 28, 2007 | 03:48 PM
GARETH T's Avatar
GARETH T
theres loads of industrial units that you could use, but you wouldnt wanna pay for them
Old Apr 28, 2007 | 10:43 PM
leecavturbo
innovate package under £400 it seems
http://tunertools.com/proddetail.asp?prod=IN%2D3784
Old Apr 29, 2007 | 10:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
voltcraft do a 4 channel handheld that does datalogging (to connected pc via rs232).
http://www.conrad-direct.co.uk/goto.php?artikel=100567
i have one, and it's pretty good. i wrote a program in visual basic to display and record the output in excel
Old Apr 29, 2007 | 12:08 PM
leecavturbo
bargain got 5 egt inconel sensors upto 1100deg C and stainless steel compression glands to weld/thread onto exhaust for £96 delivered. http://www.temperatur-shop.de/
Old Apr 29, 2007 | 01:46 PM
Jokeri's Avatar
Jokeri
http://stratomaster.co.uk/shop/?action=details&id=93
http://stratomaster.co.uk/shop/?action=details&id=94
Old Apr 29, 2007 | 02:54 PM
leecavturbo
very reasonable and with relay alarm outputs
Old Apr 29, 2007 | 03:01 PM
leecavturbo
for the money it's a little more than a wideband setup so i'm thinkinghaving just this instead,
could you virtually rely on this individual egt monitor to give you a warning of running lean?
i.e when running lean its gona run hotter which would be seen by the egt sensor and then take action?
Old May 1, 2007 | 01:39 PM
Jokeri's Avatar
Jokeri
What comes to AFR i would only trust wideband...
Old May 1, 2007 | 01:40 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
It will change the EGT if you run lean, but it will change for other reasons too, so its not really a definitive guide.
Old May 1, 2007 | 09:40 PM
GARETH T's Avatar
GARETH T
this is what i got
Old May 1, 2007 | 09:49 PM
Chip's Avatar
Chip
looks like satnav
Old May 2, 2007 | 09:17 AM
GARETH T's Avatar
GARETH T
Nov 1, 2015 06:53 PM
