CAM KIT
Old Apr 27, 2007 | 08:59 PM
powerRSturbo's Avatar
powerRSturbo
Default CAM KIT
Hi, what is the best cam kit to fit to my xr2i 1.6 8valve. thanks.
powerRSturbo
Default Fuel pump
Hi, will my xr2i go any better if i fitted a rs turbo or rs 1800 fuel pump. thanks.
Old Apr 28, 2007 | 06:35 AM
Speak to PIPER or KENT, for cams
Old Jun 5, 2007 | 05:50 PM
Dayle's Avatar
Dayle
The only one you can really fit is a kent cvh32 or a piper 285 injection although had bad experience with piper. The kent one was ok though think with eec-1v is that the airflow meter gets confused with a cam with a larger duration than 275 deg so you can't really have a wild and wacky cam.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
