Why not mild steel tubular turbo manifolds?
As title. I always thought mild steel was stronger and could handle heat etc etc better without cracking. That right?
So if so, why are all these tubular manifolds made from stainless that always crack, are a bit dodgy to use with ALS, etc etc?
If they can handle the heat better some fairly thick wall mild steel would be idea for manifolds wouldnt it?
2wd Cossie manifold can handle tons of abuse, though it has inconel in it IIRC so its not the best example, granted...
Thats the only reason i can think of, but im hoping (or not) there more to it than that.
Id MUCH rather have mental ALS and just no cracking manifolds in general than some blingy bollocks!
And besides, i bet mild is loads cheaper
Originally Posted by Bosch Dealer
Anyone have a clue about this question? The way nobody knows makes me think it is just for blingy "buy this as its pretty" reasons...
Stavros, the answer is simple. You CAN have a mild steel but no-one bothers as the cost of making a manifold is all in the labour. And Stainless is supposed to last longer etc...
To make one from mild would be about £100 less in materials...
Hope that helps mate
This is from Burns Stainless (who make pro racing exhausts) They don't even mention or sell Mild but do have 2 different Stainless Steel tubing.
304 stainless steel tubing combines excellent physical properties with a remarkable resistance to corrosive agents found in automotive exhaust emissions.
304 tube is the most cost-effective grade of nonmagnetic stainless steel for general applications, but some professional racing teams use the higher heat-resistant properties of aircraft grade 321 stainless steel.
321 stainless steel tubing is one of the most desirable materials for exhaust systems because of its excellent resistance to fatigue and cracking at elevated temperatures.
It is usually the material of choice for high temperature turbo applications, unless extreme requirements indicate the use of Inconel.
625 Inconel, containing approximately 60% Nickel and 22% Chromium, was developed to cope with the extreme heat and strength demands of jet engines.
Molybdenum and Niobium elements also contribute to 625’s strength at temperatures greater than 1800º F, where 321 SS is unsuitable.
Inconel 625 excels in applications such as Rotary engines and extreme duty turbocharger exhausts.
Originally Posted by GARETH T
nothing wrong with mild steel
Just looked at melting points, stainless is a little lower but thats still over 1400degC, so that side of it isnt the major issue i guess.
oh yes Steve,,,, the stresses dont build up so much in mild steel
Or is there other disadvantages with the stuff?
Passionford- Makes learning fun
yes its done on the inside, and regards hard use, i reckon about every 6-12 months you need to recoat it. Look at the rally cross cars.
A few people on here have had ceramic coating done and been suprised how short it lasted, and that was with mild heat, not ALS or hard hard use.
yes i mean mild steel conducts heat well,,, remember we want to keep all the energy we can for our turbine
ive go no person experience of coating on manifolds,,, but genrally they are great
of cause there downside to mild is,,, RUST,, but coatings will sort this aswell
if the coating is done right,, it should last for aslong as the manifold
BTW have you ever had a car ON THE ROAD for longer than 12 months? i know my cossie havent
no longer than 12 months? isn't that when the rust sets in
Actually, my first year ownership of my 3dr I drove it just about everyday for 12months.. that includes the snow
(even drove it to Canada from NYC and back without fault Thread
Matt Baxter
Sep 16, 2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
