Removing 2wd exhaust manifold.
Old Apr 26, 2007 | 07:18 PM
cosrep's Avatar
cosrep
Default Removing 2wd exhaust manifold.
How the hell do you get at the bolts underneath? I have some of them off but I cant get at the central four, I've tried sockets and three different 13mm spanners. None of which will fit over the nuts because the manifold itself is in the way. Does the head need to come out to get at them?
Old Apr 26, 2007 | 09:15 PM
garyrs's Avatar
garyrs
i take it buy your sig its a 4x4 manifold your takeing off ? gary
Old Apr 26, 2007 | 09:26 PM
garyrs's Avatar
garyrs
ok just read the title, dough , i took mine off last week and cant rlly say i had too much trouble, i remember 1 bolt wich is quite difficult, and think i used loads of wd 40 so it turs easy wen you have loosened it , im sure i used a stubby spanner to get in under the middle 3, the back two or mabe 3 with an angle ajustment on. can be got with a socket as can the front two maybe 3, ,,,, i take it that you have the turbo and bottle neck off the manifold? gary
Old Apr 27, 2007 | 07:57 AM
I was wondering as well given the title ?, you are getting as bad as me!!
They are a shit to get to the middle two, stubby spanner is best, although once loosened they normally turn by hand ?
May 31, 2016 09:28 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
